Results 1 to 4 of 4
carpet insulation
This is a discussion on carpet insulation within the Interior Tech forums, part of the General Discussion category; has anyone used some insulation called thermozite? has the jute carpeting and like a foillike material for heat under that. ...
    Registered User bodydropped88's Avatar
    Aug 2007
    Omaha, Ne
    carpet insulation
    has anyone used some insulation called thermozite? has the jute carpeting and like a foillike material for heat under that. gonna be redoing my carpet and found this stuff but if it's junk I don't wanna do it! here's a link. http://yourautotrim-store.stores.yah...hercarpad.html
    No trailer queen!
    Oct 2007
    south dakota
    Re: carpet insulation
    that doesnt look like junk... anything like that will help to sound proof the interior... what other options for paddings/insulators have you found?
    formerly Lkn4snow Sin City Hoe's Avatar
    Feb 2007
    Las Vegas
    It doesnt look bad. Just make sure with whatever carpet kit you order it wont be to thick. A lot of the kits come with a backing.
    Aug 2007
    Omaha, Ne
    a lot of the carpets i've found are oem molded ones. problem with mine is it's bodydropped and not an oem floor any more. the carpet i found that i'm gonna use is from the autotrim store that's 80" wide and says it's like a flexible carpet but doesn't have any backing. i figured since i need to have something under there for ins. that stuff looked like it would work, just wanted some opinions if it's been used or not. i've seen the noise killer and dynamat and all that i just figured this stuff had all in one deal. I also did find a place that had the thermozite that was double insualted on each side! might use that stuff then!
    No trailer queen!
