Call Faxon Auto Literature 1-800-458-2734 for the factory service wiring schematics.
This is a discussion on multiple light failure within the Interior Tech forums, part of the General Discussion category; Greetings, I have perused the boards for a quite some time but to no avail. My 2000 k3500 has no ...
Greetings,
My 2000 k3500 has no signal, brake, or dash lights. All of the fuses are fine, although three needed to be replaced between the box under the hood and the box just inside the door. It appears I had either a surge or a short somewhere but, upon checking again, all of the fuses are still in working order. I'll be combing through wires and checking here periodically for any suggestions you folks may have.
I should mention that I hooked up to a car trailer earlier in the day but everything worked fine initially (coincidence?).
thanks in advance
There will never be enough time untill there is no time.
check to make sure the trailer light harness is installed correctly and not correded at all. ive seen that mess up all of that before.
1999 tahoe limited. DD (sold) replaced with 09 crew cab.
1988 gmc rcsb winter/plow truck
1995 gmc ecsb project truck
my 91 had the exact same problem. It ended up being the contacts on the headlight/gauge dimmer switch. I took the switch out, cleaned the contacts with contact cleaner and it worked great after that. Thank goodness the officer that notified me that my brake lights where not working let me off with a "take the back roads home and get it fixed."![]()
Jake
1991 GMC 1500, 4X4, short bed, 5.7 liter, 4L60, BF Goodrich T/A KO 265/75R16, K&N air filter, Flowmaster
