Results 1 to 4 of 4
Door panel removal for a 2002 Silverado 1500 Extended cab
This is a discussion on Door panel removal for a 2002 Silverado 1500 Extended cab within the Interior Tech forums, part of the General Discussion category; Greetings everyone! I just bought this truck and need to get a couple of things done. First off, the drivers ...
    Apr 2008
    Murfreesboro, TN
    Greetings everyone!
    I just bought this truck and need to get a couple of things done. First off, the drivers power window is struggling... it won't go down but just a little bit and I'm having to help it go back up. Secondly, the passenger side front speaker is blown. So, I need to replace/fix both of those soon.
    Does anyone have a guide/pictures how to remove the door panels of my 2002 silverado 1500 extended cab so I can get to the guts of the door to accomplish my tasks?
    Any and all help would be appreciated!
    THanks!!!!!!!
    -Ryan
    Nov 2005
    Idaho
    Re: Door panel removal for a 2002 Silverado 1500 Extended cab
    Try looking in the audio/video forum too. Those guys get into the doors more often than anybody else.
    knows nothing, needs help xAustin's Avatar
    Jul 2007
    all over
    pry up the power windor switch assembly and disconnect the electrical connectors...use a trim tool to pry out the trim panel covering the mirror mount, and pry the trim around the inside door handle.. you can also use a a flathead screw driver if u have to.
    then find the 2 mounting screws by the door handle, you should be able to see the 1 and you exposed the other one from under the window switches. holding the door handle, pull up and out at the same time to release the panel from the clips on the door..
    02 5.3 :fsc: silverado
    Apr 2008
    Murfreesboro, TN
    Thanks for your help. It was a much easier process than I thought it would be. Definitely much easier than working on my wife's Jetta.
    The 2 front speakers have now been replaced and the drivers side regulator and motor have also been replaced... its easy!
