Results 1 to 2 of 2
dash wiring help...
This is a discussion on dash wiring help... within the Interior Tech forums, part of the General Discussion category; i did a dash swap a few years ago on my 92 and i used some information on here. i ...
    Mar 2003
    fort worth texas
    dash wiring help...
    i did a dash swap a few years ago on my 92 and i used some information on here. i found everything but the gauge wiring, i thought i used " red to green, blue to blue" type of wiring diagram but all i found was this....
    Gauge Cluster Swap for Dash Swap
    88-94 Function 95-98
    A Alternater - 19
    W Gas 16
    R Temp 13
    P Oil 15
    T Tach 6
    S Speed 14
    N,G,Q Ground 31,34,4
    F,O,U Fuse 22,7
    B Anti Lock 27
    C Check Engine 23
    E Park Brake 28
    J Low Coolant ??
    L Left Turn 3
    M High Beam 5
    V Illumination 29
    X Seatbelt 30
    Z Right Turn 32
    can some one make since of this? theres no numbers on the pulgs that plug into the back on the clusters.
    it didnt seem this difficult a few years ago when i did this lol
    1992 chebbie,bagged, 20/22, interior conversion, blah blah blah
    1997 ford f-250 as seen in 8-lug mag.
    2001 hoe, factory 20s and other bs
    Designated Smart Ass cordatta's Avatar
    Nov 2001
    San Antonio, Texas
    Re: dash wiring help...
    the plug is labeled in letters not numbers. if you look on a wiring diagram the number corresponds to the schematic of the wire.
