Results 1 to 7 of 7
Gas gauge and other questions
This is a discussion on Gas gauge and other questions within the Interior Tech forums, part of the General Discussion category; I just bought this truck 98 ext. z71 black short bed, and they said it has a new fuel pump, ...
    Dec 2008
    Washington
    I just bought this truck 98 ext. z71 black short bed, and they said it has a new fuel pump, and when I bought it the think was empty. So I filled it up and, the gas gauge was at the F mark wigging out, in at about 1/4 of an inch span back and fourth really fast, and sence then it just stays there. I use the trip counter to see how many gallons I have used. Every so offten it will read correct.
    So my question is this, is it the gauge or the sender having issues?
    Also I want to put in the overhead display. I have the concel for it, but not the display nor harness once I get those two things it should work right? Is my truck supost to have keyless entry? Its the slt, with abs.
    Registered User kev2809's Avatar
    Dec 2007
    Rosenberg, Tx
    Re: Gas gauge and other questions
    same thing happened when i bought my 98 k1500 burban...i changed out the fuel pump and sending unit and it made it read and work correctly, BUT, it still jerks around all the time, but in the same area. it always reads the correct gas, it just looks like a gas needle on crack - if that makes sense. and if they changed it drop the tank and see if the wires have been spliced (most people who change out their pumps dont go through the dealer, and these need to be spliced and rewired. because the dealer pumps have original plugs i think, so they wouldnt be spliced) hopes this helps.
    02 GMC Sierra ECSB - Billet grille, and thats it
    02 Tahoe 4x4 - Clear headlights and signals...completely stock
    67 1/2 ton Suburban - Project DRGWGN
    Dec 2008
    Washington
    I have the paper from the shop that did it. Like I said the gauge works some times, but most of the time its "on crack" at the F mark.
    Registered User east302's Avatar
    Mar 2006
    Jackson, MS
    Look at the RPO code list on the inside of the glovebox. Code AU0 (zero) is for keyless entry. If it's listed, it came with it. You can get the remotes online. Here's one place...
    http://www.keylessremotesonline.com/...productId=1721
    You can program it yourself, only takes a few minutes.
    Dec 2007
    Rosenberg, Tx
    could still be a ****ty pump they put in it, or a defective one. my pump was working fine but i changed it anyways cuz it wouldnt read right. unless its maybe your whole cluster...is any other guages erratic?
    Dec 2008
    Washington
    I think at times the oil gauge moves around a little, but I guess I deal with it reading wrong, till the pump goes out again then. No biggy just always makes me feel good, then I look at the miles I have on the tank and then it goes away
    Dec 2008
    Washington
