Results 1 to 4 of 4
custom gauges in 88
This is a discussion on custom gauges in 88 within the Interior Tech forums, part of the General Discussion category; just swapped a 97 dash into my 88. want to do custom gauges and not the factory cluster. is there ...
    Apr 2004
    arkansas
    custom gauges in 88
    just swapped a 97 dash into my 88. want to do custom gauges and not the factory cluster. is there any special things i need to buy to wire them up correctly or will they work good if i wire up just to the factory wiring. any advice would be appreciated
    Registered User crossy's son's Avatar
    Jul 2008
    Pennsville, New jersey (southern)
    Re: custom gauges in 88
    Painless makes a harness i think that will plug right into your factory harness and then it runs to all the guages.
    I think they make it
    91 Dodge 4x4 12v Cummins Intercooled/5 speed, D60 & D70 rear w/ 3.55's and a Powr-Lok--- Lots of fuel and some boost-
    SOLD-- 91 Reg. cab shortbed GMC, Black on black, 350tbi crate, 5 speed w/hurst shifter, 3.42 G80--- Over 400,000 miles on body
    Registered User Sabreslight's Avatar
    Nov 2008
    Marietta, GA
    got pics?
    Quote Originally Posted by Travelanche
    When the 4L60E falls out under the truck, the motor throws a rod, the G80 explodes, driveshaft rips apart, catches on fire, develops gonorrhea, Obama stickers randomly show up on the back bumper, or someone crashes into it at 70 mph then you have something to whine about.
    Jun 2008
    Austin, TX
    Quote Originally Posted by crossy'son
    yes they do, look at Summit Racing, Ive seen them there before.
    http://store.summitracing.com/partde...5&autoview=sku
    or
    think you still have to get sending units though but those should come with the gauges
    2000 Chevy 2500 ECSB 4x4, 6.0, 5spd
