Results 1 to 13 of 13
Seat Compatibility
This is a discussion on Seat Compatibility within the Interior Tech forums, part of the General Discussion category; I Want to swap leather seats into my 2003 silverado I am wondering what seats I can swap in? 2003-2007 ...
    Registered User Splishsplash's Avatar
    Aug 2008
    North America
    Seat Compatibility
    2003-2007 Silverados.
    What about Sierras, Avalanches, what other trucks?
    Aug 2008
    North America
    Re: Seat Compatibility
    If I swap the seats cloth to leather then...
    All the wiring for the seats is straight forward, wiring is under the seat already?
    I can hook up the heat easily? do I have to soder into the fuse box?
    What about the airbags what do I have to do with them?
    Do I have to swap the seat mounts or can I keep the ones that are in the truck?
    Nov 2008
    maryland
    bump.. im curious bout this too.. i wanna do the same thing in my 2000 silverado
    2000 silverado 1500 4.8l 4x4
    2000 silverado 1500 5.3l ext cab z71
    Nov 2008
    maryland
    bump
    Nov 2005
    Virginia
    Seats from a 99 NBS up to the 07 Classic will interchange between the vehicles.
    Now as for the wiring that will not directly interchange. I put 99 leather seats into my 05 and had to swap all the electronic sensors and seat belts from the 05's into the 99 seats due changes in sensors and connectors. It did easily swap just took time to ensure I did everything right and moved all the stuff.
    Have a nice day.
    Bill
    2005 Silverado 1500 LS 4x4 with Quadrasteer * BlackBear Performance Tune * 180 Thermostat * Airaid air intake * Dynatech Supermaxx headers with cats * Corsa dual side exit cat-back exhaust * 275/60/20 tires
    Y IM CRAZY DroppedAsAChild's Avatar
    Jul 2005
    Niagara,Ontario, Canada
    Quote Originally Posted by 05Quadrasteer
    Have a nice day.
    Bill
    WOW he's ALIVE lol havent seen you post since august lol
    1999 OBS GMC Sierra Classic ECSB 2wd-Show Truck
    1999 OBS GMC Yukon 4dr 2wd-Daily
    1990 OBS GMC Sierra ST RCSS 2wd-Factory Original
    Nov 2008
    maryland
    so what else will i need to buy for the seats to work? i mean, the truck i have now doesnt even have power seats or anything.
    Nov 2005
    Virginia
    You may not have to buy anything. Pull out your drivers seat if you can't reach the current connector under it. When you can check the connector see if you have a large Orange and large Black wire. If they are there check taht the Orange is hot and the Black will be your ground.
    Depending on what year seats you get you might be able to just connect directly into your current wiring. If it won't hook up directly then you have to move everything from your current seats into the seats you want to install.
    As for power to the passenger seat you most likely will have to splice into the hot and ground wire under the drivers seat. Run the wires under your carpet so it comes back out under the passenger seat, then hook it into the appropriate place on your passenger side.
    Have a nice day.
    Bill
    Nov 2008
    maryland
    oh ok. thanks alot, what about back seats? not sayin is has to be, but would bucket seats work in the back? i would think all ud have to do is bolt them in seperately. just goin through my oiptions here.lol
    Aug 2008
    North America
    Well I have heard that there is a possibility that the seat covers may need to be swapped. What about the airbag module does it need to stay with my truck? And to get the heated seats to work is it necessary to wire the seats into the fuse box?
    Nov 2008
    maryland
    anyone know bout changing the back bench seats to be bucket seats?
    Jul 2005
    Quote Originally Posted by red01silverado
    Have fun man lol I think theres a few threads on it type it into the search
    Nov 2008
    maryland
    searched for some info on changing the back bench seats and i didnt find anything, can you do it? or is there not enough room?
