I honestly don't know how to re-do the bottom, but looks killer so far.
This is a discussion on Redoing My door panels within the Interior Tech forums, part of the General Discussion category; After some advice from my brothers and sisters here at FSC I have begin to tackle redoing my maroon and ...
After some advice from my brothers and sisters here at FSC I have begin to tackle redoing my maroon and carpet door panels to black and suede. I will be posting pics as I go.
Before
Inbetween
and since I don't sleep that is what i have accomplished as of 1:00 am. I still am going to lightly mist some more layers to get rid of some lines in the paint.
Now for the Q and A's
1- I tore the maroon carpet off and the used goo gone and got most of all the hair off but whats left is uneven and sticky, so would it be stupid to glue suede straight to that or should i go get a flat piece of foam and mold it to the spot, glue it in place and then form suede around that or what?
2- On the fabric on either side of the door handles, the tabs broke off so i figures i would just wrap in suede then glue them back in place?
3- Anyone know how I can fix my arm rest?
Any tips or tricks would be most appreciative. When i finish this door panel you better believe I will have a in depth write up for how to do this and the materials need
1995 Tahoe-Alpine 9886, Kicker 750.1,Rockford Fosgate 40x2, 4 10" Infinity Subs,Planet Audio Line Driver.Big 3.
New to me- 96 ecsb, alpine 9886, rest of stereo undecided.
I would think mold the foam then add the suede so its finish will be nice and smooth. I wouldnt know how to fix your arm rest becuase mine is similar and I havent figured out what to do yet.
When I see how your bottom edge turns out with the suede, I might have to do mine, I think it will look really good.
94 K1500 Blueprinted355 Patriot Heads, Harland Sharp Rockers, 60103 Voodoo, 50mm TB, RPM Air Gap Intake, Hughes2500 Stall,Hedman LongTubes-True Duals, Quicksilver Shifter
http://www.cardomain.com/id/GMaChine94
Don't do suede on the door bottom, It's gonna get the crap kicked out of it and look like s**t in a month.
Originally Posted by Big Angry
Re carpet it.
You turn them into the slots.![]()
The ones I got were a little bigger than the factory clips on the oval part that goes into the panel. You just push one side into the hole, then slide the other side and twist the thing 90 degrees. They kinda snap and stay pretty snug in there.
91 RCSB C1500 4.3 4L60 Cash for Clunkered 8/3/09
09 Ford Mustang Bullitt #5998 Brenspeed Tune, LCAs. 13.35 @104.3
94 Ford Mustang SVT Cobra ModdedSOLD 9/4/08
Wow your panels are in realy good shape compared to mine. I was thinking about spraying the bottom of mine with bed liner but i dont know how well it will stick to plastic.
So, Mike Rowe is selling fords now... Definitely a dirty job.
88 GMC Serria RCLB 33x12.5x15 dayton timberline m/t
sas and sm465 swap
Idk much but i think if you would get a can of adhesive promoter it might stick after you clean it really well with something that doesnt leave a residue like denatured alcohol or acetone wipe it down really good then spray the adhesive promoter then the bed liner stuff im not sure it would work but thats what id do
Make sure its clean, scuff it up just a little, and spray away. Did that with a few of my interior peices, and they are holding up quite well with the bedliner spray.
i got mine at wal-mart... it worked and it looks good.. same stuff as youll find anywhere else probably
walmart has all sorts of good fabrics for CHEAP. I bought a few yards of black suede for like $1.50 a yard and it looks no different really then the stuff i payed $16.00 a yard for
