This is the exact console my friend installed in his 1991 with a 5 speed. It fit well and looked good after he color matched it to the dash.
This is a discussion on center floor console within the Interior Tech forums, part of the General Discussion category; i have the 4x4 shifter on the floor. will i be able to put a full floor console on or ...
i have the 4x4 shifter on the floor. will i be able to put a full floor console on or no. what about a half one like this http://cgi.ebay.com/ebaymotors/ws/eB...5704&viewitem=
thank you xZoomerZx
For that price, why dont you try building a customized one to your specifications. Just an idea.
94 K1500 Blueprinted355 Patriot Heads, Harland Sharp Rockers, 60103 Voodoo, 50mm TB, RPM Air Gap Intake, Hughes2500 Stall,Hedman LongTubes-True Duals, Quicksilver Shifter
http://www.cardomain.com/id/GMaChine94
i was not buying that one just seeing if it would fit with the 4x4 shifter on the floor
thank you xZoomerZx
Someone else was asking this so you aren't the only one...
http://www.fullsizechevy.com/forums/...r-console.html
No answer was found. Maybe someone could take some measurements from their 99-02 model so you could see where your shifter falls.
FYI, some of those short consoles on ebay originally came with the front piece and are missing a front filler panel. Kind of hard to explain, but it's part #16 in the link below...
http://www.compnine.com/index.php?u=...16&grouptype=B
Otherwise there'd be a hole in the front of the console.
