subscribed so i can remember to post pics
This is a discussion on Cb mounted in dash within the Interior Tech forums, part of the General Discussion category; I have seen some threads about where to mount cb's so i thought i would share where i put mine. ...
I have seen some threads about where to mount cb's so i thought i would share where i put mine. I never used my divorced cd player since i had my ipod so i got rid of it. I also didn't want to mount an external speaker anywhere in my truck and i like doing things the more complicated way so i wired my door speakers to a 3-way toggle switch. One side is for the radio and the other is for the CB. Oh and the wires are not still hanging out of the dash by the way.
98 ECSB 17" '06 GMC take offs, true dual straights into 4" tips, k&n, Cobra 19 in place of factory cd, 8ft whip
http://www.cardomain.com/ride/2281114
“We the people are the rightful masters of both Congress and the courts, not to overthrow the Constitution but to overthrow the men who pervert the Constitution.” -Abe
not my cb but my 2 meter ham radio, fits perfectly in the spot
btw i have cleaned up the mess of random objects and installed a different cb since then
2003 1500 Z71 ECSB, 6 HI 5000k HID's, Thrush Welded, 285 Copper AT3's, Cragar soft 8's, full leveling kit, Tonno Pro lo roll
1996 K1500, 285 Cooper STT's, 3" body lift, Cragar Soft 8's, muffler-less goodness, dual Kicker c-10's, 310k miles and counting
Here's mine, i still need to finish mounting the amp....just have it laying on the tranny hump.
Here's mine.
2004 Crew Cab Silverado Z-71Black Bear Tune
Nice! I see i wasn't the only one with that idea.
mine
2001 Z71
not all that hard...i just used a hacksaw on the inside till it fit. then used a file to smooth out the plastic.
you can see the cardboard between the cb and door, that was used for a lil while till i had time to fab up a piece of plastic to fit under the cb
2001 Z71
'99 Tahoe, 3" BL, MT II's, 285/75/16 Toyo Open Country, Duals with no mufflers
'98 Firebird 3.8L, A4 TA wheels
Here is a crude diagram of what i did. my speakers were stock so it worked, i believe the speakers have to be 8 ohm to work for the cb. Also, going to the switch from the radio i had to use just one imput or else the sound was very distorted. Basically both front speakers are fed from the left front output from the radio
okay, thanks. Maybe just add small CB speaker somewheres.
