Bump
This is a discussion on Gauge lighting and trans temp gauge within the Interior Tech forums, part of the General Discussion category; Need help guys. On my 2007 Classic half of the speedo is dark and I want to replace the bulb ...
Need help guys. On my 2007 Classic half of the speedo is dark and I want to replace the bulb with a reg bulb. I do not want to swap all the bulbs out for LED's. Soldering in the new bulb is no problem I was curious about the bulbs from Radio Shack being the same brightness as the stock bulbs.
Second on the to do list is to add a Trans temp gauge to the stock cluster. Where can I find the correct overlay and other needed items for this to light up correctly and work like it should?
Thanks for the help.
Bump
Nothing Yet?
