Results 1 to 8 of 8
Interior mirror display
This is a discussion on Interior mirror display within the Interior Tech forums, part of the General Discussion category; Ok dammit!!! This is the second FSC/GMC that I've had this problem with. This time it is on the Y2K ...
    Registered User skylark's Avatar
    Oct 2008
    Grants Pass, OR
    Ok dammit!!! This is the second FSC/GMC that I've had this problem with. This time it is on the Y2K Denali. The display on the interior mirror has gone out. Every now and then it will have one of the parts on the numbers flash up there but that is it. Is there a way to fix this thing?
    89 GMC Stepside 2WD 4/6 drop, working on the stroker again!!!
    Y2K Chevy K3500 CCLB Dually 6.5, the Black Pearl.
    Feb 2007
    Beaufort, SC
    Re: Interior mirror display
    Good luck getting someone on here to respond about this. I asked a quastion about a blinking mirror display and got zip. This is a known problem according to two different dealers in my area so it is not something that has only happened to you and me.
    May 2009
    North Myrtle Beach, SC
    Usually I don't respond to things I don't know about, but heres the response you wanted so badly.
    97 C1500
    ┌П┐(◣_◢)┌П┐ DentoTheMenace's Avatar
    Jun 2009
    Maine
    Quote Originally Posted by skylark View Post
    it should be a regular comp/temp mirror. hit up ebay or your local junkyard and just replace the whole mirror.
    Jeeps are cute, Barbie drove one.
    . __________________________________________
    ||__________||________________||___TOYOTA__||
    ||__________||________________||____________||
    88 4Runner SR5 3.4 swap and more to come
    POS 97 c1500 RCSB 4/7 drop LT1 9.5 14bolt G80 4L60e
    Feb 2007
    Beaufort, SC
    Quote Originally Posted by MrGoodtime View Post
    no help?
    Feb 2007
    Beaufort, SC
    Quote Originally Posted by DentoTheMenace View Post
    This is what I did. Problem solved for $35.00. Was however hoping some of the GM techs that troll around here would help out.
    Oct 2009
    Glen Burnie, MD
    I've seen it happen on an 05 Tahoe. My guess is that's it's probably bad solder joints on the board in the mirror, that evenually shake themselves loose. Unless you can take it apart and fix it you're probably gonna have to replace it.
    06 Silverado Z71 ECSB
    02 Cavalier - the daily MPG maker
    Oct 2008
    Grants Pass, OR
    I've been the ebay route twice in the past with limited results. I'm more than willing to rip it to shreds to see what I can find but I was hoping that someone had beat me to it.
