Results 1 to 5 of 5
Moonie Gauges
This is a discussion on Moonie Gauges within the Interior Tech forums, part of the General Discussion category; hi guys all the great info about everything is awsome this forum has helped me put my 1989 ext cab ...
    Apr 2010
    Lincoln,NE
    Moonie Gauges
    hi guys all the great info about everything is awsome this forum has helped me put my 1989 ext cab c1500 back together it was ready for the junkyard when i got her well i have the moonie style guages in my gmc and im wondering if the gauges with the needles would be a direct replacement any info will be great thank you for the great site guys
    Why don't you shirt it up 07tbss's Avatar
    Sep 2009
    Illinois
    Re: Moonie Gauges
    There is actually a sticky explaining how to do just this. There is also the gauge cluster from llate 91or 92?? i believe.. that is plug and play. But they are hard to come by and usually pretty pricey. I swapped one in my 90 that was out of a 94. With just alot of wiring and tracing. It helps if you can dig up the wiring diagram for both years (your truck) and (donor clust year) because the wires varied a little in color from year to year. I was fortunate enough to find both years on here.
    Sep 2009
    Illinois
    Re: Moonie Gauges
    http://www.fullsizechevy.com/forum/g...es-w-tach.html
    Take some time and read this. ^^^^^^ i bet i read the whole thread 5 times over before i did my swap. And a little heads up ...GM decided to use the same color wire for multiple things..I had like 3 browns 3 blues..and so on...make sure you label them before you cut that what you know what was what when u look at your pinouts. hope that helps have a good one.
    Apr 2010
    Lincoln,NE
    Re: Moonie Gauges
    thanks guys i think ill just put leds in it and the chrome faceplate that looks scary
    May 2007
    New Orleans
    Re: Moonie Gauges
    If you can find a late-'91 it is pretty much plug-and-play. They are somewhat rare but they can still be found. Make sure you get the one with the metal back.
