Results 1 to 12 of 12
escalade cluster
This is a discussion on escalade cluster within the Interior Tech forums, part of the General Discussion category; i have a 01 suburban with a 100mph speedo. can i install an escalade cluster that has a 120 mph ...
    Nov 2010
    los angeles
    escalade cluster
    i have a 01 suburban with a 100mph speedo. can i install an escalade cluster that has a 120 mph speedo and it still be accurate?
    Mar 2011
    Glendale, Arizona
    Re: escalade cluster
    No the plugs are different and are wired differently. You are better off just trying to find an aftermarket over lay that still goes to 100.
    say i wont Macedawg's Avatar
    Nov 2004
    knoxville TN
    Quote Originally Posted by Silverado777 View Post
    yes you can..i just sold a 120mph Denali cluster that proves that different
    Lost before Dawn CustomChevyGuy's Avatar
    Aug 2004
    305, South Fla
    provided the 120mph cluster is from the same generation of truck, it should swap with out any issues. i also believe that the 99-02 clusters don't require the programming to correct the mileage, since its stored on the trucks computer, rather then in the cluster itself.
    Quote Originally Posted by bhookxen
    sometimes bad-assery takes time
    71 Chevelle 454
    03 rcsb, 06 clip/tails, HD hood, 22's, Esky handles, Alpine head unit, 5% tint, clear corners, 8K HID's, FM50, 2" rear drop, debadged, BlackBear Tuned!
    Registered User mainechev's Avatar
    Jun 2010
    The Woods
    What are you smoking?
    As long as you get a cluster from a GMT800 escalade or denali, it is a direct swap
    98 Chevy RCLB K1500, 5.7, 4L60E transgo shift kit, vette servo, 14 Bolt SF, 3.73s, Blackbear 89 tune
    Mar 2011
    Glendale, Arizona
    I apologize. I assumed you were talk about an esclade cluster from an 03-07. As long as its within the same generation yes they will swap.
    FYI I'm not smoking anything. Thanks for the kind words...
    Nov 2004
    knoxville TN
    Quote Originally Posted by CustomChevyGuy View Post
    they do require the reprogramming, the local dealer quoted me an hour worth of labor to have it done
    Nov 2010
    los angeles
    thanx guys. you were alot of help. passed on one at pomona because i was not sure. next time i won't
    "INSUFFICIENT FUNDS" INDIGO95's Avatar
    Dec 2002
    Aberdeen SD
    The airbag light will be on after doing that though, there is a way to fix that problem but I'm having troubles figuring out exactly what it was that caused that.
    FOR SALE
    99 Silverado Ex-Cab, WhippleCharged 6.0, 460rwhp, converted to have 4th door,Denail clipped, flip forward hood, shaved everything, Lays frame, 20's, Indash DVD, Headrest monitors, etc. $18,000
    Supporting Member JustinSilverdo's Avatar
    Dec 2005
    Rhode Island
    The mileage is stored in the cluster on my 2001 2500, not in the truck's ECM.
    01 2500HD Duramax EFI TUNED
    88 Chevy C1500 350 TBI 5 Speed Step-a-side soon to be 6.0 swapped
    02 Cadillac Escalade
    02 HD VROD
    Registered User 01 Suburban LS's Avatar
    Sep 2003
    San Jose, CA
    Quote Originally Posted by INDIGO95 View Post
    The airbag light wont come on in a 2001. I have a 2001 Suburban and I swapped clusters. Plug an play. No issues at all. I think I read somewhere that will happen in 1999's though.
    2001 Suburban LS.
    18x10 Eagle 064's, 6" ProComp lift, Ford Keys, 1.5" rear coil spacers, 35x12.5x18 ProComp X-Terrains
    http://www.cardomain.com/ride/2175737
    Jun 2003
    Superior WI
    I had a 99 and an 02 silverado that both wore Denali clusters. Both were plug & play without lights. I just had to reprogram the odometer to correct.
