Results 1 to 10 of 10
Rain leaking into cab
This is a discussion on Rain leaking into cab within the Interior Tech forums, part of the General Discussion category; I have an 07 Crew cab that is apparently leaking from rain. I just got out of it after driving ...
    May 2006
    Texas
    I have an 07 Crew cab that is apparently leaking from rain. I just got out of it after driving to the store and noticed it. I have never seen, or felt, it before. It is on on both sides, looks like it is starting at or near the top of the doors. The headliner is wet and it looks like water is dripping (although slowly) out of the air bag inserts (or plastic covers). All 4 seat belts are pretty soaked from it and it is starting to pool on the floor.
    I do have a sun roof and I thought that may be the issue. I felt around the inside of it and did not feel any water. The headliner is also dry around it.
    Any tips/ideas for a fix? It is still raining, so I figured I would get some advice before I tried to self diagnose. It has been raining on and off for the last day, so there has been plenty of water.
    Thanks in advance.
    Midwest FSC Chapter!!
    Jul 2009
    Illinois
    Re: Rain leaking into cab
    open up the sun roof and you should see 2 little holes in each corner, these are the drain tubes for the sunroof, chances are they are probably plugged up with dirt and debris
    take some compressed air and just put the nozzle into the holes and spray them out, have someone watch under the truck and see if anything blows out when you do
    check and make sure all the seals are still in good shape also, something might have gotten torn at some point and now it wont seal as well
    hope that helps
    97 z71,3" body lift, tow mirrors, cranked and AAL, 35" KM2's, 4.56 gears w/lockright, 6k HID's, strobes/lightbar/leds
    07 2500hd ccsb lbz duramax, intake, exhaust, cab lights, leveled, about it for now..........
    May 2006
    Texas
    Thanks for the response. The rain stopped for a bit so I went out and took a look. I saw the two holes you described. I shot some air through and then poured some water in and everything seemed to flow fine. However, when we shot the air, we did not see anything shoot out. We may have missed it, but we had the truck pulled to a covered area and could not see anything.
    I checked the seals and they seem to be in good shape. I have only used the sun roof like 3 times in 4+ years.
    Any other thoughts or suggestions? The rain picked up, so I am back inside for a while.
    Jul 2009
    Illinois
    ya those drain tubes were probably just clogged up
    i would go out after a while and see if it all dry after the rain again
    sunroof drain tubes get clogged up often on many cars and trucks
    May 2006
    Texas
    Will do. Thanks again. I just thought it was weird that all the low points of the headliner would be soaked since the drain for the sun roof was right behind the front tires on each side. I'll give it some time and see if we get any wetter.
    May 2006
    Texas
    Well we got more rain last night, and I got more water leaking inside.
    For the sun roof, I wanted to be clear. The holes you were talking about were the drain holes at the front of the sun roof on each side, right? If so, those are drained.
    The rear seems to be worse than the front. The area above the seat belts for the back seats is soaked and there are litteraly water droplets forming and rolling down the sides. Floor is pretty wet and the water is running off the seat belts and onto the seats.
    Anyone have any other ideas or suggestions?
    Registered User Chevy Cust Svc's Avatar
    Jun 2010
    Michigan
    Has your concern been resolved? I would be happy to look into this for you with the last eight of your VIN. Please feel free to contact me privately. Thank you.
    Tricia, Chevrolet Customer Service.
    May 2006
    Texas
    Well we had a light rain and there was no leak, so I thought it was fixed. Then a heavier rain came and it leaked again. I read somewhere else that it could be the rear brake light, anyone heard of that or what I would need to fix it with?
    Nov 2005
    Virginia
    You can try running some clear silicon across the top and down the sides of the third brake light. Mine started leaking there this past year. After doing the silicon I have had no further problems.
    Have a nice day.
    Bill
    2005 Silverado 1500 LS 4x4 with Quadrasteer * BlackBear Performance Tune * 180 Thermostat * Airaid air intake * Dynatech Supermaxx headers with cats * Corsa dual side exit cat-back exhaust * 275/60/20 tires
    May 2006
    Texas
    Thanks Bill.
    I just did the seam all the way around the brake light, hopefully that will do it. I am going to give it a few days to get good and dry and then I will test it out.
