Results 1 to 10 of 10
Need help h instrument cluster please
This is a discussion on Need help h instrument cluster please within the Interior Tech forums, part of the General Discussion category; I just baught a 1999 Tahoe 4dr, it runs perfectly, the only problem is the gauges act a bit weird, ...
    Feb 2010
    chula vista
    I just baught a 1999 Tahoe 4dr, it runs perfectly, the only problem is the gauges act a bit weird, I been doing some reading but I still can't find a solution, hopefully someone can help me out. When I start the truck the rpm gauge reads at 3000 when the truck is idling, the fuel gauge vibrates ( but it's accurate), the volt gauge read 19v and the temp gauge reads at 110* when the truck is cold, Would I have to replace the stepper motors on all of them or is there one solution to all the gauges being wacky, any help would be highly appreciated it. Thank you
    Registered User chauncey0337's Avatar
    Mar 2011
    WA
    Re: Need help h instrument cluster please
    Sounds like it is the stepper motors but weird that they're all bad.
    2000 Tahoe LT 5.3l 4x4
    Feb 2010
    chula vista
    That's what I was thinking of doing but it does seem weird that most of them are acting up, I wonder If I can just move the needles to where they belong
    Mar 2011
    WA
    It couldn't hurt to try, I guess. My buddy's '99 yukon gas gauge vibrates also. Not sure if it's the stepper motor or the sending unit.
    Feb 2010
    chula vista
    Could it be a bad or loose ground connector??
    Registered User DylanC's Avatar
    Feb 2011
    Waxahachie, TX
    sounds like the cluster has been taking apart and needles were never put back the way they were taken off ;)
    i highly doubt its the motors, you may just need it calibrated.
    System Administration Extraordinaire
    Proud member and contributor of FSC since 2011
    Servode.com | Dedicated Web Hosting and System Administration Solutions
    Feb 2010
    chula vista
    I was also thinking that, do you have a picture of the gauges needles where there supposed to be? So I can correct them
    Feb 2010
    chula vista
    Or how do I calibrate the gauges?
    Registered User LeoP's Avatar
    Oct 2009
    Southern Md
    You'll most likely have to remove it and send it out.
    Feb 2010
    chula vista
    Dang! Where can I send it? Any one in San Diego?
