Let me preface by saying I don't know EXACTLY, but I will share this info with you;
A few years ago I took an 06 gmc SL1 and added power windows and locks. I wanted it to look factory so I tried to get factory parts. I was told somewhere along the way that 03+ uses "pulse-type" wiring that runs everything through BCM's while 02 and older uses "relay" wiring. In my case, I had to use switches and panels from 02 and older in my 05 to avoid needing a new harness and installing BCM's.
Based on that knowledge, besides the connectors possibly being different, you may also need different wiring. The bolt holes should line up though! Good luck.
LinkBack URL
About LinkBacks
