Results 1 to 6 of 6
94 K1500 - Interior Electrical Question
This is a discussion on 94 K1500 - Interior Electrical Question within the Interior Tech forums, part of the General Discussion category; I plugged an unknown AC/DC converter into the cig lighter. When I flipped the switch on the converter, the radio ...
    Torque Engineer SoCalZ28's Avatar
    Apr 2006
    I plugged an unknown AC/DC converter into the cig lighter. When I flipped the switch on the converter, the radio shut off. The 10 amp radio fuse is fine & the fuse on the back of the head unit is fine. The wipers and A/C work.
    I have since noticed the dome light also stopped working, cig lighter doesn't work, and the (open/closed-dome light) both door switches don't work.
    I have no clue... What are your thoughts???
    1994 Z71 - 6" Fabtech w/35's, MSD Ign., Headers, Memphis 12's
    *New to the family* Traxxas E-Maxx
    Apr 2006
    Re: 94 K1500 - Interior Electrical Question
    Just bump
    Im fixn to start at the cig plug and chase wires as far back as I can see, without tearing up the dash too much.
    Registered User dave89iroc's Avatar
    Sep 2007
    SE Michigan
    Check all the fuses?
    2000 Silverado 6.0 4L80E 2wd
    Supporting Member 1997chevydriver's Avatar
    Jul 2010
    Mora, Minnesota
    Quote Originally Posted by dave89iroc View Post
    What he said^^^ the cig lighter is on the courtesy (ctsy)fuse IIRC and that fuse affects everything you described
    Sent from my SPH-M820-BST using Tapatalk 2
    <------Thanks to Mean Green
    1994 K1500 ECSB Z71 5.7L 350
    1997 K1500 ECSB Z71 5.7L 350 Vortec
    Apr 2006
    I feel like a putz. Dave89iroc & 1997chevydriver you were right. Courtesy fuse, NOT the radio fuse.
    FSC Forum kicks derrière! Thanks guys!
    Jul 2010
    Mora, Minnesota
    Your welcome!
