Results 1 to 4 of 4
Moonie idiot light locations
This is a discussion on Moonie idiot light locations within the Interior Tech forums, part of the General Discussion category; I've got an 88 K2500 that I recently replaced almost the entire brake system on - front calipers & pads, ...
    Registered User 88montess's Avatar
    Jan 2012
    around, IN
    Question Moonie idiot light locations
    I've got an 88 K2500 that I recently replaced almost the entire brake system on - front calipers & pads, all rubber hoses with stainless, most of the fittings & hard lines, rear wheel cylinders and every single parking brake cable (all cut for some reason). Now that I actually have a parking brake, I've been using it fairly regularly, but a couple of times I've completely forgotten that it's on & drove a couple miles before I realized it. For some reason, the brake idiot light isn't coming on, not sure if the wire to the pedal sensor is cut, if the bulb is burned out or (most likely) the p/o removed the bulb to keep it from lighting up rather than fix the problems. That got me wondering which idiot light is where, so if anyone can help id the pic, I'd appreciate it.
    1. ?
    2. ?
    3. Check gauges (flashes for a split second when the key is first turned on)
    4. Shift
    5. SES
    6. ?
    7. ?
    8. Battery
    9. ?
    I need a tune!!! Darty03's Avatar
    Dec 2006
    Texas
    Re: Moonie idiot light locations
    http://www.fullsizechevy.com/forum/g...ml#post5004408
    Looks like its #7. If you get a flashlight and shine it on the gauges you should be able to faintly see what each light is.
    «2003 2500HD 4x4 6.0L V8»
    33" Toyo Open Country M/T, TB Crank, Tint: Front-20% Rear-5% , Brush Guard
    « 1989 Camaro IROC-Z LS1 447hp 441tq (Under the knife, 383 stoker time) »
    Jan 2012
    around, IN
    Quote Originally Posted by Darty03 View Post
    Thanks! I looked in the sticky thread on LEDs & didn't see it, but I don't think I saw that thread. I tried the flashlight trick with no luck, but maybe I just didn't get the right angle.
    Now after looking at those pictures I'm tempted to do the LEDs myself.
    Dec 2006
    Texas
    If you end up having to replace the bulb you can shine a flash light from the back side where bulb sticks in. Other than that maby someone else will chime in this time.
