sounds like the wire connector in the steering wheel fell off and is touching ground. Does your horn button work too, or is it only turning the wheel that make it go off. Also, the wire might be holding the steering wheel in place, kind of like a key or pin so you might have to force it off to fix it. that is if you haven't figured it out already
LinkBack URL
About LinkBacks
