Results 1 to 5 of 5
head liner?
This is a discussion on head liner? within the Interior Tech forums, part of the General Discussion category; how hard is it to take it out of a 88-98 fsc? how many clips?...
    I'M BAAAAACK 90slammer's Avatar
    May 2002
    Warner Robins GA
    head liner?
    Home of the Snooki punch! CKTA's Avatar
    Aug 2001
    New Jersey
    Pull off the A-pillars, the visors, the piece over the rear window and pull the tops loose of the back corner pieces....it will pretty much fall down after that.
    2013 Carlisle All Truck Nats info..
    http://www.fullsizechevy.com/forum/o...th-2013-a.html
    Registered User White Z's Avatar
    May 2003
    Houston
    when you take out those pieces where exactly do you want to pull at to get them out. im always nervous when i take off plastic dash stuff bc im afraid im gonna break it or break the tabs on it or something
    1995 GMC Z71, 9" lift (6" RCD and 3" BL),38" Mickey Thompson Baja Radial ATZ's and much more...
    http://members.cardomain.com/whitez71
    Aug 2001
    New Jersey
    A-pillars: get your fingers between them and the headliner and just pull. Then work you way down.
    The back and top pieces are the same, however....take out all the screws in the back/side corner pieces before you pull.
    Also, make sure all the pieces are warm.
    Wal-mart Sucks Timberwolve81's Avatar
    Dec 2001
    South East PA (Lancaster)
    don't forget to take off the "OH $HIT" handle
    Jake
    1991 GMC 1500, 4X4, short bed, 5.7 liter, 4L60, BF Goodrich T/A KO 265/75R16, K&N air filter, Flowmaster
