You have to cut a small square hole in your headliner at the back of the console. There are a couple of slots in the roof that two tabs on the back of the console fit into. You may also need to cut a small hole at the front of the console in order to clear the back of the map lights. Slip the console into the slots at the back, push the front up into position and install the one screw that holds it in from the front.
LinkBack URL
About LinkBacks
