Results 1 to 11 of 11
led troubles in the old radio and heater/ac contols
This is a discussion on led troubles in the old radio and heater/ac contols within the Interior Tech forums, part of the General Discussion category; I just got my led's to put in my old radio and heater/ac controls in my 92, but learned the ...
    Jan 2003
    Sterling, CO
    I just got my led's to put in my old radio and heater/ac controls in my 92, but learned the hard way why you need resistors with the led's. I have no idea what kind of resistors to get or where to put them. Anybody have any ideas or suggestions? if i get this working, ill put together a good how to change your dash light color in the older old body style over christmas break. thanks
    this first pic shows what happens to an led if you hook it up where a normal bulb goes. the one on the left kinds smoked when i turned it on, the one on the right is a normal one. The second pic is the circuit board where you have to take the bulbs out of.
    Midnight Mechanic r6z4o6's Avatar
    Apr 2002
    Bryan/College Station, TX
    oooOOooo bluueeee!!!! That will be what i order when i follow your article!!
    Is there any led specifications on the package they came in?
    http://www.superbrightleds.com/T13_specs.htm
    http://www.superbrightleds.com/bulb_specs.htm
    i have no idea what anything means on the pages that i just posted
    1991 5.3 T-56 4/6
    "A port job on 193 heads is perfume on a pig. " - 91_bowtie
    Driven hard to achieve... Stabbin97Tahoe's Avatar
    Aug 2002
    Somewhere between 41-32-02.907N / 093-39-45.355W and 44-52-49.969N / 093-13-00.921W
    Let me know how to do this. I have everything done but the radio, window, and headlight controls. I haven't tackled them yet because I'm not sure how to hook up a resistor. You can get resistors and LED's at RadioShack
    ( o )( o ) 1badgmc's Avatar
    Aug 2001
    Wichita Falls, TX
    You should be able to just get the T13s and plug them into yours since you have a '97.
    '91 GMC Sportside
    '98 Chevy Suburban
    '88 Chevy Crew Cab Dually
    '13 Ford Focus Titanium
    -- Jason
    Aug 2002
    You sure about that? And those will fit in the radio, headlight, and window controls? Seems like those are too big of a bulb What about the T1.5 Instrument bulb, or the 74 LED bulb on there website.
    Aug 2001
    Wichita Falls, TX
    Sorry. Those should be the #74s, not T13s. I've not messed with the A/C lights myself, but a couple members here say that on the '95+ trucks, the 74s (4 of them) are what work in the A/C. You can buy them with or without the base, but your stock lights should come out of the base.
    As for radio, headlight, and windows, I can't say.
    '91 GMC Sportside
    '98 Chevy Suburban
    -- Jason
    Aug 2002
    Ok, thanks 1badgmc...I already have the A/C done. However I took the 194 LEDS and just filed them down to fit, they work just as good as the 74's just a little more work
    Jan 2003
    Sterling, CO
    well, i went to put my radio back in to see what the voltages were on the light sockets before i got resistors, and the radio doesnt work know. The clock will show up when i press the rcl button, but the clock doesnt work with the key on, even though it is getting the switched power also, anybody have any ideas what the problem might be? the lights still work, the old ones.
    Sep 2003
    hell
    I believe you need 470 ohm resistors to wire up LEDs straight from a 12v source.
    Jan 2003
    Sterling, CO
    would i stick a 470 ohm resistor on each led or just one of them?
    Sep 2003
    hell
    On each one. Go to Radio Shack and buy a few, and you soder (or whatever else) them to the anode (the pin on the LED that is longer), and then just pop them in.
    Hooking up a normal LED to a 12V source = lots of smoke and big pop :)
    I've actually seen an LED explode, and its not fun.
    Sorry about how long it took to reply
