TRY FIBERGLASS. MAKE A NEW PIECE TO FIT OR JUST USE THE CUPHOLDER/WHATEVER AS A BASE. BTW, POSTS IN ALL CAPS ARE VERY ANOYING.
This is a discussion on Center Console Switches within the Interior Tech forums, part of the General Discussion category; I HAVE SEEN PEOPLE USING THE FRONT PART OF THE CONSOLES IN TAHOES AND YUKONS ETC AS MOUNTING FOR SWITCHES- ...
I HAVE SEEN PEOPLE USING THE FRONT PART OF THE CONSOLES IN TAHOES AND YUKONS ETC AS MOUNTING FOR SWITCHES- ABS PLASTIC R SOME ACRYLIC CUT TO FIT IN THE FRONT HOLE AFTER THE CD HOLDER OR CUPHOLDERS ARE REMOVED- I WAS WONDERING IF ANYONE HAS DONE THIS OR HAS PICS- I SAW IT ON CAROMDAIN AND COULDNT FIND IT AGAIN- LET ME KNOW I HAVE TO CLEAN UP MY SWITCHES I HAVE WAY TOO MANY AND NOT ENOUGH ROOM![]()
sorry bout that- im trying to make a template for wutever i decide to use but i want it to cover the entire space instead of the cupholder rectangle space. i cant seem to find a close enough match to the bends and everything
at the bottom is a pic of what i did for switches for my pre runner. im only using 2 right now and the other three are for whatever i decide to put (back up lights or something). i had a cd holder in there that i never used so what i did was cut the bottome off the cd holder and used the top to mount the switch plate. i traced the template on sheetmetal and cut it out and smoothed it out. reason i mounted it to the top of the cd holder is so that if i need quick access to my switches i can just pop off the cover no prob. the pic kinda sucks and i cleaned it up a lot more than what it looks in this pic but you get the idea
1995 GMC Z71, 9" lift (6" RCD and 3" BL),38" Mickey Thompson Baja Radial ATZ's and much more...
http://members.cardomain.com/whitez71
