did it just pop off, or did like a part break? if a part broke, stick like a needle or something inbetween for stability, than glue, if not ull have to buy a new 1.
This is a discussion on Busted the little knob off of my power mirror control. Questions. within the Interior Tech forums, part of the General Discussion category; So I snagged the little knob that lets me switch the controls from left to right and snapped it off. ...
So I snagged the little knob that lets me switch the controls from left to right and snapped it off. I glued it back on last night and this morning it just came right off, so apperantly glue doesn't work.
Can I buy just the knob or do I have to buy the entire control? It looks like it's all one unit like the headlight control.
2000 K3500(OBS) 7.4L,4L80E,CC,DRW
Yeah, it broke. I'll try the needle thing.
not necesarily a needle, just a little piece of metal or something strong enuf, make tight holes in each side, stick glue on the connector piece, stick it in 1 side, stick glue there, than stick the 2 pieces together, if ur saying the piece i think ur saying broke, im pretty sure its not gunna fix, not enuf room around a center piece to support itself, but go ahead and try it
worst case, if you buy a new 1, i might buy ur broken window switch(depending if i can figure a good way to wire the leds i put under there)
