check the fuzes. remove battery fully charge it and get it load tested.
ignition switch could be bad.
This is a discussion on Guys, can you help me with a maiden in distress?!? within the Other Rides Tech forums, part of the General Discussion category; A friend of mines 1992 Prelude shut down everything one night, but car kept running for ten min then died, ...
A friend of mines 1992 Prelude shut down everything one night, but car kept running for ten min then died, but nothing else had power.
Her parents think its a bad altenator.
I almost think it blew a main fuse possibly due to bad battery? I thought this because the car sat from around june to last weekend.
What you think? She has no mechanical knowledge and lacking funds.
If you can help me diagnosis it, I have tools to fix it.
Thanks
Used to tow Fords.
Matching Ninja 500r
I'm gonna go with a bad ground. When you say it "shut down, but kept running", I presume you mean no lights, dash etc, but the engine ran. Then ten minutes or so, engine dies also, right?
Check the main cable from the battery to the frame. Then frame to engine grounds. I'd say sitting around for a few months lead to corrosion. Also check the positive connection of course.
X2 on the ignition switch on the column. Not uncommon for this era Honda. HTH,
Scott
i'd guess battery.
this is fullsize chevy. not pintsizehonda
jk jk. my bro had a gaylude and he had nothing but problems out of it. best thing i can tell you to do is browse some honda forums and see if you can find some info to your problem. i can almost garentee you will get more info out of a honda forum quicker then what you can over here on FSC.
Im going with a bad ground. I had an 02 blazer that was doing the sametheing
Thread moved to "Other Rides Tech" section.
If I create a signature for you, please copy it to your own photo account before applying it in your User CP. Thank you.
Bob
XBL: ShortBusAzClown
