Results 1 to 14 of 14
Carb Swap
This is a discussion on Carb Swap within the Projects, Builds & Restorations. forums, part of the General Discussion category; Well guys, here it is. After helping a dude drop a carbed 383ci SBC into his NBS 2004 Silverado. I ...
    Cars & Guitars 04SilveradoMykk's Avatar
    Jul 2006
    Los Angeles
    Carb Swap
    I decided to ditch my L31 fuel injection in favor of an old school carb & manifold on my SBC sitting in my NBS that I droped in last Sept.
    There were several reasons for making this decision.
    First & formost. Because I want to...
    2nd) The PCM & fuel injection have been giving me nothing but headaches since the swap. 6-8 MPG average while delivering less power to the ground than the stock 6 cyl. Stuck in open loop, not responding to tuning, I just said "ah to hell with it..."
    3rd) The 0411 PCM required to operate the L31/4L60e is not 100% compatible with the GMT800 platform. I lost the use & function of my...
    Air Conditioning
    Oil pressure gauge
    Shift/gear indicator in the cluster
    Reverse Lights
    As well as unleash flashing error messages in the message center for sensors my truck didn't even have.
    Check oil level
    Check coolant level
    4th) Have you ever seen a old school hot rod SBC in a NBS? Yea, me neither.
    Look, the F.I unit even looks like a snail
    Professional Products 52028 manifold. A copy of the edelbrock RPM Air-Gap
    Summit distributor. Since the PCM doesn't need the cam sensor to determan RPM
    The carb: Edelbrock 1407 750cfm, jetted & rodded 4% lean for altitude. Converted to electric choke
    Modified the shaft of the primaries to fit a TPS sensor
    The carb is sitting backwards on the manifold to make easy hook up to throttle cables & TPS sensor harness. As well as having the vacuum lines on the back made for easy PCM valve & vacuum advance hook up.
    Modified the carb vacuum port & NOS fogger to inject nitrous & fuel into the secondaries. Jetted for 100hp shot
    I don't like those edelbrock foam air cleaners. But as you can see, space is an issue and it fits.
    The previously used coil now mounted on the valve cover
    The trucks original throttle cable. Fit perfect into this cheap generic chrome bracket
    Put back together, Mallory 4309 fuel pressure regulator with a return.
    I've got a few litle odds & ends to wrap up; Pipe plugs, bolts & shorter ignition wires. Those Taylor wires are too friggin long!
    With the L31 F.I. out of the way I am going to put the trucks original 6243 PCM back in place and tune out every single engine/fuel DTC.
    With the trucks original crank sensor, TPS, VSS, ECT and oil pressure sensors the PCM will be able to control the 4L60E trans and the factory gauge cluster.
    For you die hard F.I. guys out there, tough. With a 750 carb & Air-Gap manifold this engine makes 401hp/426tq on the dyno. The F.I. just could not deliver.
    And, now this engine compartment will get a double take " Huh.. a carb?!"
    Cheers ~Mykk
    Remember the 343 and 9/11 Chevyman247's Avatar
    Apr 2007
    Central FL
    Re: Carb Swap
    I knew this would happen.
    Video?? I wanna hear this beast.
    One day I need to get around to putting a roller cam in mine, my stock block is allready drilled and tapped from the factory for the spider.
    Sold--> New Truck -->
    I am a GMC Man Now!
    formerly P379XL SimpleGreen's Avatar
    Sep 2004
    Livingston, LA
    Re: Carb Swap
    Very cool Mykk. Im always game to see somebody go 'backwards'
    What was the reasoning for picking an Edelbrock? Just curious. Ive never had one. I know I have a friend that hates them. I bought my Holley just because all of us around here had more experience with them.
    - 1993 C1500 - 5.3L/4L60E Swap - 3/5 Hotchkis - '96 Interior - Tuned by EPS -
    - 2012 Camaro V6 1LT - Victory Red -
    Jul 2006
    Los Angeles
    Re: Carb Swap
    I prefer edelbrock carbs... I've owned Holleys, and all of them were leaking POS's
    I once built a 454ci, tunnel ram manifold. Dual edelbrock 500's and I've been hooked on them ever since.
    Sep 2004
    Livingston, LA
    Re: Carb Swap
    Quote Originally Posted by 04SilveradoMykk
    Thats cool. My Holley before this one was a leaky POS, so I had my friend swap it for another while he worked at Autozone. Ever since its been on my 350 though its ran like a champ.
    formerly 133
    Nov 2005
    Far away from YOU
    Re: Carb Swap
    You gonna post new exhaust/driving vids when done?
    04 Sierra-LM7
    Waiting on spring, Needs to be faster! Just ask TheBigBlackHD-
    Quote Originally Posted by TheBigBlackHD View Post
    no no no no no no no no nO NO NO NO NO! Please NO! I cant be "the guy whos truck got beat by the guys truck with the camo headliner"!
    Jul 2006
    Los Angeles
    Re: Carb Swap
    Quote Originally Posted by WetPaintYukon
    Of course, I couldn't imagine the exhaust note being much different except it might not be as Sharp as it previously was.
    Jul 2006
    Los Angeles
    Re: Carb Swap
    Spare Parts
    dreamin of a 6x6
    Dec 2007
    lawton
    Re: Carb Swap
    wheres that k&n element going,that would be nice for my 79
    1979 silverado k20 454,4 speed,body lift,homemade cowl hood,homebrew front bumper,humvee tires
    Quote Originally Posted by GreaseDog
    stick with your truck, if she has any sense at all, she'll be leaving you soon anyways. no sense in putting yourself into any more debt.
    Jul 2006
    Los Angeles
    Re: Carb Swap
    99.9% done.
    Made a upper coolant hose to work, finished wiring the ignition as well as shortened the spark plug wires, put in new NGK TR55's, Filled it back up with green coolant.
    The only thing left to do is get a fitting; 3/8" pipe 90* to a 5/16" hose barb for the fuel return line. Than I can check for any fuel leaks, and make sure the fuel pressure regulator is doing what it is supposed to.
    Than to test fire, set the timing, adjust idle, tune the carb and take her for a test drive.
    Cheers ~Mykk
    Jul 2006
    Los Angeles
    Re: Carb Swap
    It's alive. Still needs tuning, of a none PCM nature :P
    http://www.youtube.com/watch?v=IwfN_-xU40Q
    There is still one issue that's currently getting resolved. The fuel return line is to small to successfully regulate the 60PSI down to 6PSI and the return line is getting backed up and causing too much pressure at the carb.
    Plan: Drop the tank, remove the in tank pump and run a generic electric pump on the frame rail. The pump I found runs 72GPH @ 5.75PSI. And I should have the second part of this swap finished in a couple days.
    Cheers,
    Mykk
    Jul 2006
    Los Angeles
    Re: Carb Swap
    Today I tackled the thank & F.P.
    Replaced the in-tank pump with a piece of straight line
    using the soldering gun to cut away the plastic to tighten the hose clamps
    welded the fuel pump bracket to the cross-support
    tomorrow I'll tap into the existing FP power lines and put the tank back up.
    Jul 2006
    Los Angeles
    Re: Carb Swap
    I've been driving the truck since last thursday. No problems, it has alot more of everything. Better torque, much better power, better gas milage, better exhaust tone & a more controlled "cammed" idle
    http://vimeo.com/3125480
    I didn't notice the black rich smoke until I was filming, I've since stepped the accelerator pump down a notch and it cleared it up
    I put my 6243 PCM back in place and it's nice to have my oil pressure gauge and shift indicator back as well as getting rid of erroneous messages in the gauge cluster. I've yet to turn off DTC's via HPTuners, but the trans still shifts just fine
    Cheers ~Mykk
    0_o o_0 0_o o_0 98GreenMachine's Avatar
    Aug 2005
    St. Paul, MN
    Re: Carb Swap
    Looks cool man
    I know you will attract alot of negative carb-related attention, but hey, its what you want and its working out better than the L31 FI was so more power to ya
    98 K1500 Z71 - 204k | L31 | 60E | 3.73's | 3" BL | 33x12.5x15 Dick Cepek F-C II's | Dynomax Ultra Flo X DI/DO | 14 MPG
