Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Underhood Reel Light
This is a discussion on Underhood Reel Light within the Projects, Builds & Restorations. forums, part of the General Discussion category; Got a reel light on eBay for $20. Installed it today. I've seen them on older OBS trucks, but not ...
    Registered User daved931's Avatar
    Apr 2008
    Bangor, ME
    Got a reel light on eBay for $20. Installed it today. I've seen them on older OBS trucks, but not any of the newer ones like mine. I assume this is because GM was mounting them on the passenger side fender near the battery and once they went to the Vortec engine in 96, the Vortec air box got in the way.
    The light I got had a wiring pigtail on it that looked factory. It had a cylindrical bus fuse holder with a ring terminal on the end for power and another ring terminal for ground. I went to put a standard bus fuse in there holder and it was too long. Not sure what would go in there. Maybe one of those little Bosch ones I've seen in older Volvos??? I should post a pic. Anyway, I hacked that off and put in a fuse holder for a blade style fuse. I put a ring terminal on the end and put it on the stud where power runs into the fuse block on the driver's side. I drilled a small hole in the inner fender, took the paint off around the hole and then mounted the ground with a self tapping screw and washer which I then covered with grease to protect it.
    I mounted the reel to the PCM mounting bracket on the driver's side. The light works and it's got enough cable to go all the way to the far corner of the truck.
    There's no hood switch or anything, the reel light has a manual on/off switch, which I really like.
    Sorry for the crappy cell pic.
    1999 2 Door Tahoe 4x4 w/ 14 Bolt SF & TruTrac. Corvette servo, Gibson cat-back, custom tune from Black Bear, AD244 alt. upgrade, Z71 skid plates, Escalade cluster, 2" block + 1.5" crank, 285/75R16 SOLD 1/2012
    2008 Silverado 1500 Z71, Borla catback, block and coil spacer
    Registered User SpeedDevil's Avatar
    Mar 2007
    St. Louis
    Re: Underhood Reel Light
    My 96 vortec with the monster air box has a reel light. looks good! I like them.
    Apr 2008
    Bangor, ME
    Cool. I didn't know they were available that late. Where is yours mounted?
    Ima lechoo finish, but... TheFreeman2005's Avatar
    Dec 2008
    North Carolina
    Yeah, I love that thing! I used it a bit tonight as a matter of fact.
    One of the most dangerous political philosophies afflicting America today is the belief that we can’t allow anyone to suffer the natural consequences of their own stupidity.
    May 2009
    kentucky
    mine doesnt work
    Aug 2005
    somewhere else
    I've seen them on Vortecs up on the firewall, passenger side. They're cool but so far I haven't had to use one for anything.
    Richard
    Apr 2008
    Bangor, ME
    Oh, cool. See, learn something new every day.
    Australian Chevy
    Feb 2006
    Melbourne, Australia
    Yep....I bought one and put it in place of the underhood light.
    Trying to find a pic. You can see it in this one.
    Howard
    YOU ONLY NEED TWO TOOLS IN LIFE - WD-40 AND DUCT TAPE. IF IT DOESN'T
    MOVE AND SHOULD, USE THE WD-40. IF IT SHOULDN'T MOVE AND DOES, USE THE
    DUCT TAPE.
    98 K1500 Suburban, 4L80E, Whipple SC, Marine Intake, Hydroboost, LS1 0411 PCM.
    Apr 2008
    Bangor, ME
    I like that mounting location. Looks like you've got a full engine bay with that Whipple Charger.
    miss you Rachael tatoodkelt's Avatar
    Dec 2006
    Bowie, Maryland
    Good stuff man. My 94 and my 95 both have those. I have an extra from my 96 parts truck that I'm planning on putting on my 99 Suburban.
    70 Chevelle * 73 Chevelle * 94 RCSS * 95 2 dr Tahoe * 99 Suburban
    70 Chevelle rebuild here
    Quote Originally Posted by JWolfe75 View Post
    I'm also a pop-in-pooper......
    Jul 2009
    Phoenix
    Got a part number for the OBS trucks reel light?
    Formerly Redneck Rebel Dale Gribble's Avatar
    Dec 2006
    Lima, OH
    http://www.lmctruck.com/icatalog/cd/full.aspx?Page=149
    At 20 bucks I'd say you got a good deal.
    "The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government"
    ~ Thomas Jefferson
    Supporting Member
    May 2007
    North Dakota
    I've thought about this. So far it's stayed that way. Should get on it.
    You probably tried an AGC fuse, which is most common. Maybe an AGX or AGW?
    http://www.bussmann.com/pdf/7e17b38e...9b51f75907.pdf
    '00 Chevy RCSS 4x4/Z71 FOR SALE!!! - '98 Harley-Davidson Sportster 883 - Scroogle
    Quote Originally Posted by neonclown View Post
    I'm not sure you can bash ignorant people by being ignorant, but A for effort.
    Jun 2008
    California
    Quote Originally Posted by sunburnedaz View Post
    12341801 Lamp Pkg. List $79.16 Cost $55.77 Only 3 left new, from GM. Go to the dealer, ask for a parts locate.
    1999 Chevy Silverado Z-71, 5.3L, auto, reg. cab, long bed, LS, Indigo Blue, 4.10 gears, locking diff, floor mounted transfer case, Rancho lift, 285/75r16 BFG mud T/A's, AR-23 16x8, 98 silver Z-71 decals, Tahoe grill, XM, keyless door handles, side tint 16%, rear 4%, amber DRL's, ordered new 4/99.
    Aug 2005
    somewhere else
    Or just grab one from the boneyard in any pre-95 OBS...they were pretty much standard equipment on all but the most base model.
    Richard
    Registered User Chevy1500z71's Avatar
    Jun 2007
    Fl
    i used to use mine to top off my rear end at night when the pinion seal leaked on the old 10 bolt. also used it when my flex plate was missing half its teeth and i had to turn the motor over with a wrench to catch a few good teeth to start it lol. that light has always served me well through all the junk stages of my truck. id install one of those things on any vehicle.
    money pit- 1995 k1500, 4 bolt 355, whipple, nv4500, 14bolt semi floater.
    turd box dd- 1994 5spd cummins
  17. #17
    Apr 2008
    Bangor, ME
    I don't have the part number. As noted below, you can buy new through LMC truck. I scored mine from an auto scrapper on the Internet.
  18. #18
    Dec 2006
    Bowie, Maryland
    Quote Originally Posted by someotherguy View Post
    Richard
    My 95 has one too.
  19. #19
    Apr 2008
    Bangor, ME
    I think I'm going to go outside and play with mine (reel light). I almost forgot how sweet it is.
  20. #20
    GMT400--Part collector
    Sep 2008
    tennessee
    I have a 95(its an SL) and it didnt come with one. Is the factory pigatil to hook it up tucked away in there somewhere ?
