what year is the 454, some are more desirable then others
This is a discussion on 454 swap within the Projects, Builds & Restorations. forums, part of the General Discussion category; I have a 94 4x4 with a 350 and the trans is a 5 speed manual with the granny low ...
I have a 94 4x4 with a 350 and the trans is a 5 speed manual with the granny low . Ive found a dually with a 454 and automatic trans. Can I swap motors, computers, and wiring harnesses?
ok what im wanting to know is can i get a truck with a big block and use its wiring harness and computer to put in my truck . Ill rebuild the bigblock for more power
If you got the funds then yes. the ecu will need to be tuned.
