Results 1 to 10 of 10
5.3 running rich?
This is a discussion on 5.3 running rich? within the Technical / Maintenance forums, part of the General Discussion category; My 5.3 (2002) Tahoe has a sooty black tailpipe. Is it possible that it is running rich? I average about ...
    Oct 2004
    So Cal
    5.3 running rich?
    My 5.3 (2002) Tahoe has a sooty black tailpipe. Is it possible that it is running rich? I average about 13-14 mpg, some say this is to low. Ideas?
    Thanks
    The One Smokedawg's Avatar
    Nov 2002
    Indiana
    Re: 5.3 running rich?
    Is that 13-14mpg highway or city. If thats a little of both, thats about right. I do about 18 mpg highway and 14 city. You can get a fuel pressure regulator and might be able to pick up an adjustable fuel pressure regulator.
    -Smoke
    2008 GMC Sierra - 5.3L, 6" lift, 35" Nittos, K&N CAI, Rhino Liner
    1990 Mustang GT- 347 Stroker, Nitrous, full suspension and lots more
    1995 Chevy S-10 - 406 SBC, 400 Turbo, Dual tunnel ram, Dart 215 Pro1 heads, Nitrous, full tub, 9in rearend
    Oct 2004
    So Cal
    Thats over all average. I can get an adjustable fuel pressure regulator? Also, I thought you only did that if you were boosting? Also, is an air cleaner (which one?) and a cat back exhaust worth any mileage or performance?
    Nov 2002
    Indiana
    I am unsure if you can get them for trucks. What year is your truck? I run a AFPR on my S-10 and Mustang and neither are boosted. Just helps fine tuning.
    -Smoke
    Nov 2002
    Indiana
    Nevermind..i see its a 2002
    Oct 2004
    So Cal
    bump
    Registered User jebx's Avatar
    Oct 2003
    Minnesota
    Any check engine light? Also, 2wd or 4wd? How many miles? Stock? Differential gear ratio? Any work been done on it?
    2001 RCLB Silverado 4x4 4.8L - Dynomax cat back - K&N FIPK
    Apr 2004
    Grand Rapids, MI
    That fuel mileage sounds low to me...
    My '01 5.3L, 4x4 ECSB Z71, all stock, with a 3.73 rear gets an average of 15.8mpg, 60/40 City/Highway... never less than 15.5mpg. It touched 20mpg on all freeway, on the way down to Florida with probably 1000lbs in the bed. I'm relatively heavy footed as well.
    2001 Chevy Silverado LS EC/SB Z71 | TB Crank | 5.3L | 3.73 | 285/75R16 BFG KO2 | Dick Cepeck DC-2 16x8 | MBRP XP Series S5018409 T409 Cat Back Dual Split Side Exit
    Oct 2004
    So Cal
    Jeb, no check engine light. 43K miles, bone stock 3.42 gears, always premium fuel 2WD. Ideas?
    Old Man William Kanter's Avatar
    Apr 2004
    Texas finally
    Switch to 89 octane gasoline, cheaper too.
    2005 GMC Sierra Z71 - Jet Black, modding in progress
    2002 Silverado ext. cab LT - Black w/ gray leather, 22x9.5 Weld EVO Slingblade 6's
    2001 Honda Accord coupe
    New project truck: 1984 Silverado SC/LWB, midnight blue, lowered 5/7, rebuilt 454, 20x8/20x10 combo on order!!
    (rides)
