Results 1 to 2 of 2
1993 k1500 Engine Codes
This is a discussion on 1993 k1500 Engine Codes within the Technical / Maintenance forums, part of the General Discussion category; My truck is showing to have codes 22 and 43. It will sometimes shift bad, but I can turn it ...
    Dec 2004
    Texas
    My truck is showing to have codes 22 and 43. It will sometimes shift bad, but I can turn it off, restart it and the shifting problems end for awhile. AutoZone told me it was the TPS sensor so I replaced it and am still having the same problems. Does anyone have any ideas on what needs to be replaced??
    Apr 2004
    Vernon B.C.
    Re: 1993 k1500 Engine Codes
    Code 43 is the Electronic Spark control according to my Hanes manual.It says the probable cause would be:ESC sensor is not recieving a knock signal from the knock sensor.It says to check the knock sensor or the ESC module.
    The Hanes book explains how to do this.The book is a good investment.
    Disconect the Battery for a while to clear the codes.The 22 should go away if you replaced the tps.
    93k 2500 5.7tbi
    01 18hp Craftsman Ride On MOWER(with beer holder)
    12ft harbercraft flyfisher w/4.5 merc.
