Results 1 to 20 of 20
2000 5.3 silverado starting problems
This is a discussion on 2000 5.3 silverado starting problems within the Technical / Maintenance forums, part of the General Discussion category; I've got 2000 silverado with a 5.3 automatic and 65k on the odo. The thing gets tempermental with starting. When ...
    Oct 2004
    Scranton, PA
    Question 2000 5.3 silverado starting problems
    I've got 2000 silverado with a 5.3 automatic and 65k on the odo. The thing gets tempermental with starting. When the truck sits for a few hours or overnight it fires on the first crank. If it sits 15 to 30 minutes it cranks right up. Now when it sits between 45minutes and a few hours it doesnt want to fire. If I keep on cranking it for 15, 20, 30 seconds it will fire up, but with hesitation,... seems like it builds up to a steady running...
    Truck has a new fuel filter.. injectors are cleaned. Dealer "claims" the fule pump is fine.
    Any ideas would be greatly appreciated.
    Thank you.
    Norbert
    Oct 2004
    Scranton, PA
    Re: 2000 5.3 silverado starting problems
    Anyone anthing?
    Oct 2004
    Scranton, PA
    I'm going to try a new fuel pressure regulator. I will keep this post update, maybe someone will find it useful later on.
    Mar 2005
    St. Cloud, MN
    Yeah, update us on that, I've got the same truck with twice the mileage and the same problem occurs pretty much all the time. I'm almost convinced that the pump works fine except for a check valve. We hooked up a fuel pressure guage to it and turned the key to "on." The pressure went up while the pump was pumping, but as soon as it shut off all the pressure drained back into the tank. So as long as I try firing it while the pump is still pumping, i will usually get it to fire.
    But let us know what happens with your regulator.
    -SS-
    Waiting for spring..... SBCStang's Avatar
    Sep 2003
    Syracuse New York
    My dad's 2000 5.3L had the same problem. After reading a bunch of threads about FP regulators, I checked his. Pull off the vacuum line going to the FPR. If fuel comes out, the regulator is BAD. Changed it out and the problem doesn't exist anymore.
    What happens is, if your interested, when cold the engine is set for rich anyway, so the extra fuel is just burned. When the engine is warm, the fuel leaking past the FPR into the intake through the vacuum line is flooding the engine and it will be hard to start and when it does finally, it will run very rough.
    Chris
    '95 C1500 Ext Cab SB
    Can't forget my street car - Chevy powered 1983 Ford Mustang coupe
    Mar 2005
    St. Cloud, MN
    Yeah, that sounds exactly like my problem- when it fires it sputters for a little bit and idles rough...
    Registered User shreckengost's Avatar
    Mar 2007
    Pa
    did anyone find out if this fixed the problem?
    '00 Silverado Z71 5.3L RC/SB
    Not Really Bob
    Jan 2006
    Newark, DE
    It did, trust me Happens to nearly everyone with these trucks, including myself.
    99 Silverado ECSB 4X4, LQ4, Patriot Stg. 2 243's w/ 59cc chambers, TR224-112, Pacesetter LT's, Nelson tune, FLT Lvl 5.5, PI 3400, UD pulley, 160* t-stat, E-fans, 6'' Fabtech lift, 3'' body lift, 37'' XTerrains, 4.56's, 4'' shackle flip 13.3 @ 99mph on 37's or 13.0 @ 101mph on 31's
    Mar 2007
    Pa
    did it tonite - already noticed the difference. Thanks!
    Oct 2008
    eastern shore of maryland
    im havin the same problem.. it kicks my azz
    ^Compliments of O4NCZ71^
    2000 Silverado 5.3L 1500 4x4,Leveling Kit w/ 3in. Rear Blocks,35x12.50 SS Thornbirds,16x10 Black DC-1's,True Duals No Mufflers w/ 4in. Magnaflow Tips,5% Rear Tint,Tractor Supply Black Truckbox
    Designated Hitter
    Jul 2005
    West Richland, WA
    Where is the fuel pump regulator on a 97 GMC K1500?
    97 GMC, K1500, 5.7L, Still too stock.
    Mar 2008
    OKLAHOMA
    same problem here!!! did anyone else have an alternate answer to fix this? ive changed everything from map sensor to plugs, wires, fuel filter. iam lost at this point
    formerly 99-2door Sinister C3's Avatar
    May 2005
    Broken Bow, OK
    Quote Originally Posted by Desighitter View Post
    Inside the intake manifold, under the black plastic upper piece.
    May 2005
    Broken Bow, OK
    Quote Originally Posted by adamw89_2000 View Post
    Did you change the FPR?? Cause that's probably what it is.
    Nov 2005
    Pittsburgh, PA
    I had the same problem with my 1999 Sierra w/ the 5.3L
    Nov 2008
    sc
    I had the same problem with 2000 silverado 5.3. FPR is an easy fix
    2003 Chevy 2500HD Single Cab 6.0L 291k
    2000 Chevy 1500 Extended Cab 5.3L 237k
    1955 Chevy 3800 1 Ton Flatbed
  17. #17
    UNDER CONSTRUCTION.......
    Nov 2003
    indiana
    anyone got pics of this?
    my dads 2000burban does this from time to time... sometimes fires right up no problem, other times she just doesnt want to start or runs ruff wanting to die so hes gotta keep the pedal down to keep it running.
    his burb only has like 50K miles on it and hes had it since new.
  18. #18
    May 2005
    Broken Bow, OK
    Don't have a pic on hand, but look on the fuel rail, driver's side where it crosses over. Little round can with a vac hose running to it. Take the vac hose off and if you see fuel in there, def bad.
  19. #19
    Registered User UnderBoost's Avatar
    May 2007
    Lake Forest
    Cool Re: 2000 5.3 silverado starting problems
    Same problem here!!! 2000 5.3 LT.. I have a new Delco regulator on it also. Fuel psi is fine, Pump energizes etc. I notice when I do start it and it stumbles like stated above and it will run like that for awhile if you look at the volt dash gauge it will drop when stumbling. I found when that happens shut it down and restart and the problem goes away. wtf?? I am now experiencing an small arc type sound down by the new Delco starter and the radio says 1:00 as of today only during start up it's happened twice today. Just had the Battery tested and that tested fine. I'm going to pull the starter down and look for any pinched/worn electrical issues.
    I think we are dealing with an electrical ground problem.
    00 LT Chevy 5.3 Extra Cab. Stock
    87 Buick Grand National
  20. #20
    Redonkulous Gorp's Avatar
    Jul 2007
    Chicagoland
    I just finished changing out my FPR on my '00 Z71 W/5.3L. I had exactly the same symptoms and when I pulled the vacuum line to replace the regulator fuel was present.
    My service manual suggests a light coat of oil on the "O" rings to ease install and I'd suggest that.
    Also, look for the small "O" ring from the original regulator inside the fuel rail, I needed to fish mine out since it didn't come out when I pulled the original regulator out.
    I'm thinking this will be the fix!
    Thanks all!
