Results 1 to 7 of 7
5.3...323 or 327?
This is a discussion on 5.3...323 or 327? within the Technical / Maintenance forums, part of the General Discussion category; I always thought the 5.3 was a 327. I had someone who says he knows a good amount about the ...
    Jul 2005
    Michigan
    5.3...323 or 327?
    I always thought the 5.3 was a 327. I had someone who says he knows a good amount about the 5.3's tell me it's actualy a 323. 323 was a motor GM used years ago?
    Jim
    2011 Silverado 1500 LT Ext. Cab, 5.3, 4X4, tow package, 3:42 w/ locker, BOSS standard 7.5 Poly Plow
    www.3n1autocomputer.com All FSC members can get a Scangauge2 at a discount, ask me how in a PM.
    bikes cars trucks women vic_V8's Avatar
    Jan 2004
    Dixon IL
    Re: 5.3...323 or 327?
    gm used a 327 (4.00 x 3.25)
    5.3 is a 325 (3.780 x 3.622)
    '84 K30, 7" lift, Converting to International Diesel HP 60/14 combo
    '88 GMC Suburban V2500 5" lift 60/14 with 4.10s 5.3 LS swap TH400/NP208
    '94 GMC Suburban K1500 350/4L60e with updated heads, mild upgrades
    '77 Ford F250 High Boy 400/C6/Divored 205 44/60
    Veteran of Afghanistan (Army SSG)
    Feb 2002
    Tulsa
    325
    Jul 2005
    Michigan
    Ok, You guys swear by 325, but when I did a parts search at Rock Auto.com. their database reports it as a 323 also??? Could it be the 2005's have a slightly smaller displacement?
    Jim
    Some kittens can fly! mikeoxlong's Avatar
    Apr 2005
    Austin
    Summit Racing also lists the 5.3 as a 323. The GM sales guy i bought my truck from back in 99 told me 327.
    ----------------- Chuggs's Avatar
    Nov 2001
    Southern Virginia
    Here you go:
    Quote Originally Posted by media.gm.com
    Engine * Type * Displacement (cu in / cc)
    Vortec 4300 4.3L V-6 (LU3) * 4.3L V-6 * 262 / 4300
    Vortec 4800 4.8L V-8 (LR4) * 4.8L V-8 * 293 / 4807
    Vortec 5300 5.3L V-8 (LM7) including Hybrid model * 5.3L V-8 * 325 / 5328
    Vortec 5300 5.3L V-8 (L33) * 5.3L V-8 * 325 / 5328
    Oddly, the 2004 info says that the 5.3 is a 327, but the bore and stroke are unchanged from then til now at 3.78 x 3.62
    Formerly escalaradoon22s Escalarado's Avatar
    May 2005
    Baton Rouge
    ballpark, its around 61.04 cubic inches per liter...you do the math.
