Results 1 to 8 of 8
1992 Chevy 2500 5.7l Idle Problem
This is a discussion on 1992 Chevy 2500 5.7l Idle Problem within the Technical / Maintenance forums, part of the General Discussion category; I Have A 1992 Chevy 2500 4wd W/ 5.7l With A Manual Transmission. I Had A Problem With Missing Out ...
    Sep 2005
    INDIANA
    I Have A 1992 Chevy 2500 4wd W/ 5.7l With A Manual Transmission. I Had A Problem With Missing Out Between 1500 And 2000 Rpm. I Installed New Plugs, Wires, Distributor Cap, And Rotor. It Doesn't Miss Out Anymore But Now It Will Idle At About 800 Or 900 And Then All Of The Sudden Die On Me. It Will Do It Setting Or If I'm Coming To A Stop And Push In The Clutch. Basically When There Is No Load On The Engine And The Idle Gets Below 1000 Rpm. I Am Sure Work That I Just Did Is Fine Because It Runs Fine When I Am Actually Driving And Not Setting Idle. Any Suggestions Would Be Appreciated.
    GMC RULZZ NEUMANNZZ's Avatar
    Mar 2005
    San Diego
    Re: 1992 Chevy 2500 5.7l Idle Problem
    check the computer for codes. go here: http://www.fullsizechevy.com/forums/...ght=obdi+codes
    Matching Ninja 500r
    Aug 2005
    somewhere else
    If it's really idling around 800-1000 then it's not idling too low; it sounds like you may have a vacuum leak. You might have disturbed a vacuum line or two while doing your tune-up, or your TBI base gasket may have given up.
    Richard
    Sep 2005
    INDIANA
    The Service Engine Light Has Not Come On.
    Sep 2005
    INDIANA
    I Have Already Checked The Vacuum Lines And Rechecked Them Again After The Suggestion. Today I Used Throttle Body Cleaner And Cleaned It Out Real Well But Still Not Much Better.
    05 GTO upgrade.
    Apr 2004
    Texas
    Your IAC might be stuck. It is the thing on the passagerside of the throttle body towards the back. It is round and about 3 inches long with wire coming out of it.
    1991 C1500 Ext. Scrapped. I still have the engine, tranny and Detroit tru-trac.
    2005 GTO LS2 with full Pedders track II suspension. StreetsweeperHT cam with Kooks exhaust. Tuned.
    Sep 2005
    INDIANA
    I will take a look at it. Is there a good way to check it or unstick it if needed?
    Mar 2005
    San Diego
    clean it with carb cleaner, try not to move it is electrically activated and controlled by the computer.
    Matching Ninja 500r
