Results 1 to 3 of 3
95 chevy c1500 extended cab, Blower Motor Resistor Location
This is a discussion on 95 chevy c1500 extended cab, Blower Motor Resistor Location within the Technical / Maintenance forums, part of the General Discussion category; My Blower motor only works in high speed, suspect bad blower motor resistor. Where is this bad boy located exactly? ...
    Nov 2005
    Florida
    My Blower motor only works in high speed, suspect bad blower motor resistor. Where is this bad boy located exactly? Do I need to remove anything to get to it? Any input would be much appreciated.
    Registered User SpitAndDirt's Avatar
    Aug 2004
    Barksdale AFB, LA
    Re: 95 chevy c1500 extended cab, Blower Motor Resistor Location
    Remove glove box door and look at the top of the A/C box. There should be a relay you can feel clicking when you put the fan on high. In the immediate vicinity of that relay is the connector for the resistor. The resistor assembly screws into the A/C box. Hope you find it -Chris
    Registered User Rickdef17's Avatar
    Aug 2005
    Livonia, MI
    I just had to do mine. It's not that bad. I also replaced the switch and connector because mine melted. I think the plug cause all the problems so check that. Working good now.
    "Stupid is as stupid does Sir"
