Results 1 to 15 of 15
96 Chevy K1500 Quit and Won't Start
This is a discussion on 96 Chevy K1500 Quit and Won't Start within the Technical / Maintenance forums, part of the General Discussion category; 96 chevy k1500 vortec 350 quit but wont start. Fuel pump is running, and is getting spark when turning it ...
    Mar 2006
    new york
    Exclamation 96 Chevy K1500 Quit and Won't Start
    96 chevy k1500 vortec 350 quit but wont start. Fuel pump is running, and is getting spark when turning it over. I have checked to make sure their is voltage to the injectors with the key on and their is twelve volts to each set of wires. have installed new fuel filter and new ignition control unit with no avail. I also have recently changed plugs, wires, distributor, cap, and come to find out it was the engine to chasis ground. It ran fine for eight months and last night i was driving down the road no spit or sputter it just quit. I towed it home and put the filter and icu on it. It is getting gas up to the injectors cause i took the lines off and gas pours out while turning it over. Spark is not a problem believe me cause i felt it going through my body. Any Suggestions would be greatly appreciated. Thank you cause im at wits end.
    Registered User Blackfoot's Avatar
    Mar 2006
    California
    Re: 96 Chevy K1500 Quit and Won't Start
    Quote Originally Posted by trayrick69
    I dunno, but it sounds like you awnsered your own question here.........
    Mar 2006
    new york
    ok it may sound like i answered my own problem but after finding the bad ground wire and changing all them parts it ran great for eight months before it just quit again. I am trying the fuel pressure test today, and will get back to this to let you all know. Any other ideas would be appreciated.
    Oct 2004
    Woodstock Ontario Canada
    Check the fuel pressure, it should be between 55-65 psi. It could be the fuel pressure regulator.
    peace
    Pauly
    Mar 2006
    new york
    Lightbulb Re: 96 Chevy K1500 Quit and Won't Start
    Only have 18 psi. On my way for a new fuel pump...... Let ya know latter.
    Mar 2006
    new york
    Mar 2006
    new york
    Only 18 psi. On my way for a new fuel pump. let you know later.
    Homesick NBer
    Jul 2005
    Edmonton, AB (but still an easterner at heart)
    pump might do it, but i herd pauly say maybe a fuel pressure regulator. to me18 psi pressure, better get the pressure regulator too.
    2003 Chev Silverado 4x4 4.10 gears and it has a 4.8L
    1997 GMC Sierra 4x4 4.3L 4L60E KOSS CD player,16mpg,3.73 gears z71 skid plates <<<sold
    4th year apprentice at Chev Dealer
    Powered by Vortec 97sierra454's Avatar
    Nov 2005
    Burlington, CT
    Sounds to me like a fuel pump internal regulator problem where the pump won't hold pressure but will pump gas under no pressure and still works. This happens often to this style of pump.
    1997 Sierra 2500HD 4x4, 454, ECSB
    1998 Silverado K1500 Z71, 350, ECSB
    2009 Pontiac G8 GT Sport
    Oct 2004
    If the fuel pressure regulator is screwed up, it may be lettuing fuel just return to the tank instead of restricting the flow and allowing pressure to build in the rail.
    If it a fuel pressure regulator, it is located inside the upper plastic intake manifold. This would be the perfect time to install the updated GM MPFI Conversion Kit.
    Scroll to the bottom of this link, there is a picture of the kit.
    http://www.pacificp.com/forum/viewtopic.php?t=981
    this kit includes a new fuel pressure regulator, 8 new updated TRUE fuel injectors(you can see them at the ends of thise 8 hoses).
    The 4th picture from the bottom of this link sjows the original poppet style injectors above the new GM MPFI Conversion spider. You can clearly see the injectors at the ends of the hoses.
    http://www.performancetrucks.net/for...d.php?t=356743
    Here is the parts list and prices
    Part: 93441235
    Category: Fuel Injector
    Description: INJECTOR
    Min.Qty: 1
    Unit Price: $188.34
    Quantity: 1
    Ext.Price: $188.34
    Core Charge: $0.00
    Part: 93442096
    Description: BRACKET
    Min.Qty: 1
    Unit Price: $7.06
    Quantity: 1
    Ext.Price: $7.06
    Core Charge: $0.00
    Part: 17113206
    Category: Manifold Gasket
    Description: SEAL KIT
    Min.Qty: 1
    Unit Price: $19.60
    Quantity: 1
    Ext.Price: $19.60
    Core Charge: $0.00
    SUB TOTAL: $215.00
    SHIPPING: $49.03
    TAX: $0.00
    TOTAL WITH TAXES: $264.03
    These are a bunch of pics ofthe intake manifold.
    http://www.pacific-audio.com/perform...es/231640.html
    GM realized how bad the stock "poppets" are and was forced to engineer an improvement. If you live in California, you can get this replaced for free as it is an emissions issue, the Cali gas gums up teh stockers from what I hear.
    I would rule out a fuel pressure regulator first, its easier to pull that upper intake, off than it is to drop the tank or lift the bed to get at the pump assembly. In my opinion anyways.
    peace
    Pauly
    Mar 2006
    new york
    Cool Re: 96 Chevy K1500 Quit and Won't Start
    Thank you all for your input... It was the fuel pump, I lifted the bed and the lines were rusted bad. I replaced the fuel pump and 2 foot of each line, Runs great now. Thank you all.
    Jan 2006
    county
    Quote Originally Posted by Pauly
    Part: 93441235
    Min.Qty: 1
    Unit Price: $188.34
    Quantity: 1
    Ext.Price: $188.34
    Core Charge: $0.00
    Part: 93442096
    Min.Qty: 1
    Unit Price: $7.06
    Quantity: 1
    Ext.Price: $7.06
    Core Charge: $0.00
    Part: 17113206
    Min.Qty: 1
    Unit Price: $19.60
    Quantity: 1
    Ext.Price: $19.60
    Core Charge: $0.00
    SUB TOTAL: $215.00
    SHIPPING: $49.03
    TAX: $0.00
    peace
    Pauly
    I live in CAlif Is GM still doing these replacements? I got a bad regulator--would this be replaced by gm still?
    Oct 2004
    I am not 100% sure, if I am not mistaken I think GM was forced to extend the injector warranty to 10 years the poppet injector problem is an emissions issue. Check with your local dealer.
    I dont know if GM will do a fuel pressure regulator under this extended warranty or not.
    peace
    Pauly
    Mar 2006
    Minnesota
    If you pinch off the return line and you have good pressure you need and regulator if the pressure dosn't rise your fuel pump is shot
    Jan 2006
    county
    peace
    Pauly
    I noticed when I took off the upper intake,there was NO hose attached to the pressure regulator. Nor could I find ANY evidence of a hose under there.
    I noticed in the pictures you site http://www.pacific-audio.com/perform...es/231640.html
    there are no hoses attached or seen on those presssure regulator.
    Is there supposed to be a hose attached, or does the manifold vacuum provided the suction?
