Results 1 to 3 of 3
2007 5.3L Horsepower?
This is a discussion on 2007 5.3L Horsepower? within the Technical / Maintenance forums, part of the General Discussion category; Anyone know how GM got 35 more horsepower out of the new 5.3L? (285 hp as on my 2002, vs. ...
    Feb 2006
    Dayton,Wa
    Question 2007 5.3L Horsepower?
    Anyone know how GM got 35 more horsepower out of the new 5.3L? (285 hp as on my 2002, vs. 320 hp)
    Jan 2006
    Holland/Kalamazoo, MI
    Re: 2007 5.3L Horsepower?
    I can't answer you with 100% certainty, but I would imagine that it is just different tuning over the 2006 aluminum 5.3L that many of us (including myself) have which is rated at 310. Just a guess, but that is more than likely what it is. As far as the 5.3L that I have versus the other lower rated ones, I've read many differences. Some internals I believe are different, also a different cam, and higher compression, along with tuning I imagine.
    Nick
    Oct 2004
    Woodstock Ontario Canada
    The 310 hp L33 5.3 got its 15 hp boost from the iron block 295 hp LM7, from ifferent heads, a small compression ratio bump, slight lift increase via the cam and tuning changes.
    In the new 5.3 I can see GM doing a little more of what they did for the L33 aluminum block L33.
    here is the new engine power lineup from GM.
    L92 6.2 VVT 380-400hp
    L76 6.0 VVT & DOD aluminum block 355 hp
    LY6 6.0 VVT iron block 350hp
    LY5 5.3 2wd DOD&E85 comp. 320 hp, 335 or 340 lb/ft depending on app.
    LC9 5.3 4wd DOD&E85 comp. all alum.310 hp 335 lb/ft
    LY2 4.8 iron block 290 hp
    peace
    Pauly
