Whoa AZ was wayyy off there bud... you need to use Synchromesh fluid... not only is it Synthetic, its a lot thinner... you will wear your synchros with 80-90..
or another, you can use a Synthetic 5-30 motor oil...
This is a discussion on 1995 chevy z71/k1500 manual transmission noise within the Technical / Maintenance forums, part of the General Discussion category; I have a 1995 z71/k1500 with a 5.7l, and 5 speed granny transmission, recently replaced the clutch pack and upon ...
I have a 1995 z71/k1500 with a 5.7l, and 5 speed granny transmission, recently replaced the clutch pack and upon start up noticed a whine when in gear or in neutral, the noise goes away when i engage the clutch, have checked the linkage, checked the clutch slave, checked the transfer case, redropped the tranny, everything checks out ok, but noise is still there... only thing i can't rule out is the fluid.... i got the fluid specs at autozone..
GL5 80w90 is what i was told to use... but now the dealer says syntorque fluid...can the difference between synthetic and regular oil make the difference in noise? anyone had this problem? i'm gettin po'd with my truck.
Jay Bernard, Thibodaux, LA
2005 GMC Sierra crewcab, 5.3, LS1 hot cam, z06 springs, 93 tune by thunder racing, Trailblazer converter, 3:42's, G80, 4-6 drop, Joe gibbs wheels
1962 Chevy Longbed fleetside, 235 straight 6 dual rochester carbs, split header, glasspacks andflamethrowers!
unfortunately it was a sunday, and i had to get the truck back together asap.
figures, az has gone down in the past few years... i'll swap my fluid out. just wondering if the standard oil was making it whine like it was trying to go in gear.
Did you figure this out? My 88 is doing the exact same thing.
On the note of manny tranny fluid, GM synchromesh fluid seems to be the stuff that ton's of people swear by, even the import crowd likes it. Anyways that's what I found out when I was researching to replace my fluid, and it has worked pretty well. Dunno if this helps but thought I'd share.
yeah man, take out the other crap, put in synchromesh.
1995 GMC Sierra 2500 4x4 5.7L 5 speed manual W/T
Just trying to research! Like every other site people don't always say what fixed the problem. Mine does it until i shift into 4th. 5th doesn't whine either. From looking around it seems a little whine is normal, just thought it was odd it only did it in 1,2,3 gears. I also have a little chatter when releasing the clutch that just started when I was driving it home. Just bought it today.
I do plan to put synchromesh in it, might flush it with the pennzoil synchromesh then put the gm stuff after running it a bit.
If you just bought it today, I'd suggest change all the fluids, trans, motor, diffs. changing the fluid in the trans may get rid of it.
2007 2500HD Silverado 2WD Regular Cab 6.0LY6 6-speed auto 4.10s, Super 44 Flowmaster, Blackbear Tune. Put some duct tape on it, and Screw you, I'm from TEXAS!!!
yeah, i've already got $150 of making sure it's caught up on preventative maintanence. Just wanted to see if i had a new clutch/flywheel/bearings in my near future.
