Results 1 to 13 of 13
best way to level my truck
This is a discussion on best way to level my truck within the Technical / Maintenance forums, part of the General Discussion category; What would be the best way to level my truck? I see these new torsion bar keys and wonder how ...
    Jan 2006
    La Grange, MO
    What would be the best way to level my truck? I see these new torsion bar keys and wonder how good they are. just wantin' to get everybodies opinion.
    Brandon
    new truck
    1999 Chevy Silverado LS 1500 Z71
    old truck
    1992 GMC Sierra 2500 LD 350/700r4
    (mods "HOPEFULLY" soon to come)
    May 2006
    Cogar OK
    Re: best way to level my truck
    What kinda truck?
    Any suspension mods done already?
    I leveled my 88 longbed ext cab with a pair of $20 rear shackles, and have had no problems. I don't know if there are superior methods...
    Jan 2006
    La Grange, MO
    it's a light duty 3/4 ton. i don't want to lower the rear, i want to level it by raising the front end. and no suspension mods.
    Brandon
    new truck
    old truck
    96 Silverado, Black, Ext 2006_RoadGlide's Avatar
    Mar 2006
    central Illinois
    If it's 4WD it should have Torsion Bar adjustment to it to raise it. Just make sure you turn the bolt the same number of turns on both side.
    May 2005
    Carrollton, TX USA
    You can crank the torsion bars up. This will get you about 2" of lift. The best way to do this is to measure the front of the frame, jack up the front end adjust the torsion bars, lower the truck and drive around to settle the suspension and remeasure at the same point. Do this until it is at the height you want. You may have to crank the bars different amounts to get the same amount of lift out of each side.
    May 2006
    Ga.
    I lifted my 2003HD4x4, bought new "pork chops" torsion key ways for suspension products. Had a dealer install as it is suppose to take a special tool, you can do it with simple hand tools but the t-bar is under tension.the new pork chops allow more than 2 in.cost was $69 plus shipping. the front end had to be realigned after the twist.
    Jan 2006
    La Grange, MO
    i really don't want to crank my torsion bars because i heard that could break stuff, and don't have the money to fix anything. that's why i wondered about these torsion keys. i know there's the tech article about how to put new keys on in the tech section. i might try some of these keys, and have someone put them on.
    Brandon
    new truck
    old truck
    I Also Drive A Ram!! CahtasZ's Avatar
    Jan 2006
    Wesson, Mississippi
    i cranked the torsion bars on both my trucks and it leveled it out on both. we took measurment and all that good stuff gained about 1.5 to 2 in. on both and level it out
    !!!FIRST TO GO LAST TO KNOW!!!
    94 GMC Sierra 4x4. work in progress..stock.
    07 3/4 Dodge Ram,CUMMINS,4wd,35 Open Country's
    Registered User 96redsportside's Avatar
    Aug 2003
    Hermitage, TN
    You can do get the t-bar keys, or there's a spacer you can buy that sits on top of the coil spring and pushes and adds an inch or two, most people around here seem to prefer the t-bar keys/crank. It seems like an easier process from what I've read.
    Jan 2006
    La Grange, MO
    96redsportside, i'm pretty sure only 2wd have coil springs, cause i know mine don't have any.
    Brandon
    new truck
    old truck
    Aug 2003
    Hermitage, TN
    Quote Originally Posted by bmdean
    My bad, I should know better.
    you me
    Registered User gmsales2006's Avatar
    Mar 2006
    Eastern Shore of Maryland
    using the ford keys or cranking the stock keys has the same effect on the front end, the ford keys allow for more crank. I went with the keys on my half ton and love the stance. There are plenty of 3/4 tons out there with 2" of crank, I doubt you would have much trouble due to the stronger front end components.
    Mall R8D
    May 2003
    near Richmond, VA
    Quote Originally Posted by gmsales2006
    Agreed
    2003 Chevy DA EC/SB 4x4
    1983 GMC Jimmy ZZ502 ~ 1988 Chevy K5 ZZ4
    1987 Chevy K5 HT383 ~ 1983 K10 364ci 578RWHP
    1995 Chevy K2500 454tbi ~ 2005 Nissan Armada
