Page 110 of 115 FirstFirst ... 1060100108109110111112 ... LastLast
Results 2,181 to 2,200 of 2291
Like Tree3Likes
Finding Out If Your Vehicle Has A Recall Is Very Easy
This is a discussion on Finding Out If Your Vehicle Has A Recall Is Very Easy within the Technical / Maintenance forums, part of the General Discussion category; What about me? Vin= 2GCEK19T221380372 02 silverado 5.3 Can you also pm me about where it was Made and the ...
  1. #2181
    Registered User Chevy53's Avatar
    Mar 2012
    Boston MA
    What about me?
    02 silverado 5.3
    Made and the other details about Vin and what they mean?
    current mods -
    Cree reverse light bulbs
    Candied tails
    Blackbear Tune
    Future
  2. #2182
    Registered User Benny00Z71's Avatar
    Oct 2009
    Roy, UT
    Re: Finding Out If Your Vehicle Has A Recall Is Very Easy
    Tricia,
    My dad's '05 L33 is consuming a lot of oil; 1.5 qts in 1500 miles with 70,000 on the odo. I have read that a poorly designed valve cover is the issue here. Is this an issue that can be fixed as a recall? If not, what are the options? This problem seems to be getting worse with both his L33's. Any help wold be appreciated. Feel free to PM with details.
    Thanks!
    2000 Silverado 5.3L ECSB, Z71, G80, 3.73
    General Grabber AT2's, Corsa Catback, Vette Servo, Stock Air Intake, 4500K HIDs
  3. #2183
    Registered User Chevy Cust Svc's Avatar
    Jun 2010
    Michigan
    Quote Originally Posted by Chevy53 View Post
    What about me?
    02 silverado 5.3
    am not showing any open recalls for this vehicle at this time. I will contact your privately with more information. Thank you.
    Tricia, Chevrolet Customer Service.
  4. #2184
    Oct 2010
    Southern Illinois
    Vin=2GCEK19R6W1263355
    1998 Silverado K1500
    Thanks
  5. #2185
    Registered User 78mc-bbc's Avatar
    Feb 2011
    Rhode Island
    My vin is 3GNFK16T14G288809
    2004 Suburban K1500
    Any recalls?
    Thanks!
  6. #2186
    Jun 2010
    Michigan
    Quote Originally Posted by Z71ornone View Post
    Thanks
    I am not showing any open recalls for this vehicle at this time. Please contact if you need further assistance. Thank you.
  7. #2187
    Jun 2010
    Michigan
    Quote Originally Posted by 78mc-bbc View Post
    Any recalls?
    Thanks!
    I am also not showing any open recalls at this time for this vehicle. Let me know if you need anything else.
  8. #2188
    Apr 2012
    Lafayette, La.
    My vin #3GNEK18R2WG127868
    98 Thaoe Z71
  9. #2189
    Jun 2010
    Michigan
    Quote Originally Posted by Xanatost View Post
    98 Thaoe Z71
    I am not showing any open recalls for you vehicle at this time. Please feel free to contact me if you have further questions. Thank you.
  10. #2190
    Apr 2012
    Lafayette, La.
    Quote Originally Posted by Chevy Cust Svc View Post
    Thanks a bunch!! :-)
  11. #2191
    Sep 2007
    Long Island, NY
    any help would be appreciated vin#1GCHK29152E251025 also, is it possible to go to the dealer and have them print out a service history for the same vin?
  12. #2192
    Registered User bonecolector's Avatar
    May 2012
    Brandon, MN
    Great Thanks
  13. #2193
    Jun 2010
    Michigan
    Quote Originally Posted by Lays Low View Post
    I am not showing any open recalls for this vehicle at this time. Your local dealer should be of more assistance in terms of maintenace history. If you would like build information, please feel free to contact me via private message. Thank you in advance.
  14. #2194
    Jun 2012
    north carolina
    Hello could u run a couple of numbers for me please? 2GCEK19V941272478......1GCHK33J1XF083013
  15. #2195
    Jun 2010
    Michigan
    Quote Originally Posted by 3500HDaddict View Post
    I am not showing any open recalls for either vehicle at this time. Are you currently experiencing a concern? Please feel free to contact me for more assistance. Thank you.
  16. #2196
    Jun 2012
    Jonesboro, LA
    Quote Originally Posted by TRITON20 View Post
    if people want to post their vin # here on the board, i will run those #'s through GM at work to see if anyone has outstanding recalls and also give a little description of them
    keep in mind, vin #'s over 10 yrs old may no longer be in gm's data base
    sorry to say that i am not doing this anymore, but others who work at dealerships are carrying on this tradition... still post your vins
    Please check my truck for recalls - 2GCEK19T6Y1312665
    All (again ALL) of my brake lines are completely covered in RUST and pitted very badly and in the past 2 weeks I have had 2 line break (spring leaks from pressure) and I dam near died TWICE because of this (blow through a 4-way stop intersection - no one there at the time and on a sharp corner, that goodness there was a wide open field for me to drive into). I replaced the MAIN LINE running to the rear (1st leak) and then just 1 week later the line running to the RT front brake went out. I have NEVER seen brake lines this bad before and I have lived in the worst areas of the country (AK, KY, CO, TX) for metal (ie road salts, sea salt, etc) THERE MUST BE A RECALL on these lines!!!!!
    And I have looked up recalls on line and this year model has several recalls. I bought this truck from an elderly man 4 years ago and he had GM replace the drive shaft per a recall. My park brake has never worked and I am even replaced the cable TWICE, I did see a recall for this but not 100% sure!
    Thank you
  17. #2197
    Jun 2010
    Michigan
    Quote Originally Posted by icetman View Post
    Thank you
    I am not showing any open recalls for this vehicle at this time. Have you brought this to the attention of your local dealer? Please feel free to contact me privately with more details for further assistance. Thank you.
  18. #2198
    Jun 2012
    Ohio
    I have an 05 Yukon--VIN# 3GKFK16Z65G243769
    Thanks for checking--I have a 4WD issue that I thought could be solved by replacing the encoder motor--but no luck. Car is still intermittantly shifting into N or 4WD, even at high speeds. I posted in here on 6/29 to see what else it could be. Please take a look and comment here or there if you can--thanks!
  19. #2199
    Jun 2010
    Michigan
    Quote Originally Posted by mthlist View Post
    I am not showing any open recalls for this vehicle at this time. I am also not showing any information relating to your concern. Have you had a chance to contact your dealer? I would recommend giving them a call to see if they can offer other ideas. Contact me if you need additional assistance. Thank you.
  20. #2200
    Jul 2012
    Waitsfield VT
    1996 Chevy 1500 van. 1GBFG15r6T1025958, Please and thank you!
