Body Control Module? I have heard of that here, but no idea what it actually does.
This is a discussion on 04 silvarado is throwing a U1041 code..... within the Technical / Maintenance forums, part of the General Discussion category; U1041 - Loss of EBCM Communication. What the heck is this? (ebcm)...
Document ID# 1734167
2004 Chevrolet Chevy C Silverado - 2WD
Subject: ABS Light On, DTCs C0265, C0201, U1041 Set and/or Loss of Communication with Brake Module (Reground EBCM Ground) #04-05-25-002C - (11/23/2005)
Models: 2004-2005 Buick Rainier
2002-2006 Cadillac Escalade, Escalade EXT
2003-2006 Cadillac Escalade ESV
1999-2006 Chevrolet Silverado
2000-2006 Chevrolet Suburban, Tahoe
2002-2006 Chevrolet Avalanche
2002-2005 Chevrolet TrailBlazer, TrailBlazer EXT
2003-2005 Chevolet SSR
1999-2006 GMC Sierra
2000-2006 GMC Yukon, Yukon Denali, Yukon XL
2002-2005 GMC Envoy, Envoy XL
2002-2006 GMC Sierra Denali
2004-2005 GMC Envoy XUV
2002-2004 Oldsmobile Bravada
This bulletin is being revised to provide further diagnostic information and add 2006 model year full-size vehicles. Please discard Corporate Bulletin Number 04-05-25-002B (Section 05 -- Brakes).
Condition
Some customers may comment that the ABS light is on. Upon further inspection, DTCs C0265 and C0201 may be set in the brake module. It is also possible for DTC U1041 to set in other modules. There may also be a loss of communication with the brake module.
Cause
A poor connection at the EBCM ground is causing unnecessary replacements of brake modules.
Important: The EBCM Ground is different for each application. Refer to the list below for the proper ground reference:
• Midsize Utilities = Ground 304
• SSR = Ground 400
• Fullsize Trucks and Utilities = Ground 110
Correction
DO NOT REPLACE THE BRAKE MODULE.
Perform the following steps to improve the connection of the EBCM Ground:
Remove the EBCM Ground. The EBCM Ground is located on the frame beneath the driver's side door. If multiple grounds are found in this location, the EBCM ground can be identified as the heavy (12-gauge) wire.
Clean the area, front and back, using a Whiz Wheel®.
Install the ground, then the washer and then the bolt to the frame.
Important: It is important to use the bolts, washers and nuts specified in this bulletin. These parts have been identified due to their conductive finish.
Install a washer and nut to the back side of the frame.
Tighten
Tighten the nut to 9 N·m (79 lb in).
Cover the front and back side of the repair area using Rubberized Undercoating.
An additional check can be made to ensure a good connection for the Battery Cable to Frame ground. It is possible for this ground to cause similar symptoms with the ABS as described above.
Parts Information
FULL-SIZE TRUCKS, SUVs AND H2
Part Number
Description
11588564
Bolt
15650962
Washer
15672934
Nut
12378398
(in Canada, 10952414)
Rubberized Undercoating -- Paintable
MIDSIZE SUVs
Part Number
Description
11517555
Bolt
15650961
Washer
11503749
Nut
12378398
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
N9502
Ground Repair - EBCM Ground
0.2 hr
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
Thank you for your help.![]()
p.hinds is a wonderful person.
- Russ
Gonna go check mine tomorrow...
'07 DBM Vortec MAX CCSSB
'03 HD Fatboy (57K... many upgrades)
'00 HD FXDL (wifes weekend toy)
'91 ECLB DRW, 502/4L80E, Slammed
'87 Grand National
'87 Olds 442 (Blue/Silver)
'84 Monte SS (They all idle like that... trust me)
p.hinds rules....
Ground is not the cause of my problems... gonna pull the ABS module and send it to modulemasters.com
'87 Grand National
