Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
5.3L Horsepower and Torque ratings
This is a discussion on 5.3L Horsepower and Torque ratings within the Technical / Maintenance forums, part of the General Discussion category; also 05 is when they started the E-fans instead of the Clutch fans like 04 and down wasnt it?? didnt ...
  1. #21
    Registered User 951500's Avatar
    Sep 2007
    atlantic canada
    Re: 5.3L Horsepower and Torque ratings
    also 05 is when they started the E-fans instead of the Clutch fans like 04 and down wasnt it?? didnt that help any on the 05 models? just my thought
  2. #22
    Registered User mred's Avatar
    Feb 2007
    TEXACO
    ls6 cam and 2500 stall should be plenty in a truck?
  3. #23
    Dec 2003
    TN.
    old thread i know but need some advice from some of you that would know. I have a 1999 ecsb 4x4 with 4.8 and 3.73 gears. I tow 18 1/2 foot ski boat and it strains to pull it. Until i can afford to do a bigger engine swap, will sending the pcm to blackbear help with the towing or, because it is a 1999 with this dreaded slow PCM you guys speak of, will it not help?
  4. #24
    Dec 2003
    TN.
    anyone?
  5. #25
    Jul 2005
    Euless, Texas
    Quote Originally Posted by 89chevy View Post
    99 had a weaker camshaft grind that sacrifices mid-range grunt. Also the 99 ECM code is horrible and notorious for false knock retard. Upgrade to a 2002 Tahoe calibration and it will wake it up tremendously. The 2002 Tahoe was tuned to make 275 HP @ 5,200 and 290 TQ @ 4,000 from a 4.8. The 1999 was rated at 255 HP @ 5,200 and 285 TQ @ 4,000. Eliminating false knock and increasing the timing by running the 2002 Tahoe calibration will really wake the 4.8 up. Same thing goes for using the later 5.3 calibration on a 99 5.3.
    1997 G1500, 5.7, 906s 2.02/1.60, GM 395' marine cam, 1.7 RR's, Marine Intake, BBK TB, 85mm MAF, 6.5 aircleaner, Thorley Tri-Ys, Thunderbolt 2.5 cats, Dynomax 22865 muffler, 4L80E, 0411, Hydroboost, 9.5" 14-bolt 3.73s, 8800 GVW front calipers, March 4490 pulleys, AD244 alt, D-Max fan
