Results 1 to 15 of 15
2000 Silverado Starts then Dies
This is a discussion on 2000 Silverado Starts then Dies within the Technical / Maintenance forums, part of the General Discussion category; Hi, I am new to this forum and would like to say hello to all and ask a question. I ...
    Dec 2006
    Missouri
    Hi, I am new to this forum and would like to say hello to all and ask a question. I have a 2000 Silverado with a 5.3 engine, when I try to start it, it fires right up and dies instantly. The security light flashes when I open the door and turn on the key, but it goes away in a few seconds. I have had a Key cut to the VIN at the dealer, and I have tried the relearn procedure several times. Does anybody have any thoughts on what it could be?
    Thanks
    Terry
    Dec 2006
    Tennessee
    Re: 2000 Silverado Starts then Dies
    Im not too familliar with the newer models but are you sure it might be something to do with the security sys. on it.Can you here your fuel pump when you turn the key on to see if it is building pressure,because it may be weak.
    Aug 2005
    Cape Cod
    I just had that problem, Was my Fuel pump! Pumped just enough to get it to fire. $279 for new pump at AutoZone
    2002 Chevy Silverado Z71, 4.8 4X4 EXT Cab, 3.73 gears(GT4). With 2" lift, via rear leafs from a 2500, & cranked T Bars
    Dec 2006
    Missouri
    I have replaced the fuel pump with a new one from Napa. I can hear the pump running. The truck sounds like it is running perfect and not starving for fuel. For a couple seconds at least.
    Jun 2006
    Pittsfield, MA
    Fuel pressure regulator gone bad? Clogged fuel filter?
    Does it do it when hot, cold or both?
    Can you keep it running by feathering the gas pedal or no?
    Jul 2005
    Louisiana
    Make sure your battery cables are screwed in tight. I had the exact same problem with my old 2000 Z71, so I undid the cables and re-tightened them and the problem never came back.
    -Cory
    Dec 2006
    Missouri
    Yeah, I have cleaned the battery cables and replaced the battery.
    I'm just stumped, the local dealer wants $400 to replace the ignition switch and passlock II sensor, but they can't be sure that'll fix it. The big problem is that I'm 30 miles from the dealer. Thanks for you help guys..
    Mar 2006
    St. Louis
    Question Re: 2000 Silverado Starts then Dies
    Quote Originally Posted by tdoyle
    Yea, what he asked. Does it run with your foot on the gas?
    Oct 2004
    Woodstock Ontario Canada
    I bet its the VATS.
    The VATS will allow the truck to run for a coupel seconds, then it kills the injectors and stops the engine from being fueled.
    The new key must be introduced to the system.
    This is a PDF file that contains all teh different VATS systems relearn protocols.
    http://www.bsecorp.com/files/techtips/ST9303l.pdf
    peace
    PAuly
    Jul 2007
    AR
    Quote Originally Posted by BurbanFoot87
    I had the same issue this morning. Took the truck to the gas station to get a drink and when I went back out to leave the truck started, then started to idle ruff and then just died. I could get it started again if I kept feathering the gas and was able to make it home. The whole time trying to make it home the ABS light, Battery light and Parking brake light would come on and off and headlights would go in and out??? Could all this be fuel pump related? I'm hoping it's just a loose wire somewhere. Any thoughts?
    Jul 2007
    AR
    ***bump***
    Registered User chrias's Avatar
    Aug 2005
    Markham, Ontario, Canada
    I have the same problem with my NBS 2000 Suburban. This is the second time it's done it. Tooke me 10 minutes to finally get it started. A friend of mine suggested that maybe the crank sensor may be on it's way out but I'm getting no codes.
    My pump was replaced 1 1/2 years ago and a full tune-up has been done this year. I know that sometimes when I drive and floor it, it will sputter and it will sometimes sputter and want to die when I take off from a stand still but then it will be perfectly fine.
    claviz13
    Guest
    Quote Originally Posted by Pauly
    I bet its the VATS.
    Agreed.
    Feb 2007
    Louisiana
    Checked your connections between the alternator and battery?
    Aug 2003
    Alberta, Canada
    Definitely VATS
    1996 GMC Sierra K1500 LWB - DD
    1980 GMC Sierra Classic K25 LWB - The Project
