Page 1 of 2 12 LastLast
Results 1 to 20 of 27
'95 Z71, vortec engine?
This is a discussion on '95 Z71, vortec engine? within the Technical / Maintenance forums, part of the General Discussion category; I'm gonna go look at a '95 Z71 for sale with a V8 engine and a automatic tranny here in ...
    Jan 2007
    McKinney, TX
    I'm gonna go look at a '95 Z71 for sale with a V8 engine and a automatic tranny here in a second. Is this the first year for the vortec engine? What should I look for? How is the tranny? I've had 2 trucks with 700R4 trannies and I think this one has that tranny. Should I be worried about this tranny. I going to test drive it in a little bit. Just let me know pretty quick, thanks.
    Signature edited by FSC Staff for violating the forum for sale rules.
    Original Gold Member 97Silverado's Avatar
    Nov 2001
    Newcastle, Texas
    Re: '95 Z71, vortec engine?
    No, '95 was the last year of the TBI. If you want a Vortec you need to look for a '96-up. That '95 will have a 4L60E transmission.
    Much like alcohol, tobacco, and voting there should be an age requirement for computer usage.
    "Drag racing helps me get rid of all my extra cash."
    Team credit card holder and crew chief - "Hot Rod" Heather JD4193 & Holly "Wood" JD4145
    Jan 2007
    McKinney, TX
    Should I really wait for the vortec it has 99,000 on it? Is the vortec worth it? How does the 4L60E transmission usually hold up?
    Jan 2007
    McKinney, TX
    Anyone?
    4/6 dropped Silvy on 22s
    Jan 2006
    C town Illinois
    Both the TBI and Vortec are great engines. If you want more power and speed stock, then get the Vortec. You can also make the TBI as strong as the Vortec but it will cost you. I have the TBI and have no problem with it. My Tahoe has the Vortec 350 and it is faster than my TBI but not by much. If you are into speed, Vortec.
    The Flying Dutchman neevnav's Avatar
    Jan 2007
    Stouffville, Ontario, Canada
    The TBI is far easier to work on. And my 4L60E went 403,000 KM before needing a rebuild, and that was ONLY because my old man was trying to tow his tractor out in reverse with it and broke the reverse drum.
    Oct 2005
    Vancouver, WA
    I got a '95 (see my vehicle specs below)......it works and was purchased at the "right price." So I can't complain.
    Besides.....you know how they say...
    Last year of the model.....they should have got the bugs worked out by then.
    First year of the model......they started w/a clean sheet and don't know the problems to come.
    Here are my RPMs:
    55 MPH_____1550 RPM
    60 MPH_____1675 RPM
    65 MPH_____1825 RPM
    70 MPH_____1950 RPM
    75 MPH_____2050 RPM
    (sometimes I get)
    55 MPH_____1550 RPM
    60 MPH_____1650 RPM
    65 MPH_____1800 RPM
    70 MPH_____1925 RPM
    75 MPH_____2100 RPM
    2000 RPM_____73 MPH
    Transmission in OD……flat part of the freeway (I-5).
    __________________________________________________ _______________
    15.5 MPG
    City only driving
    16.116 MPG 7-24-06
    Combined city/highway/freeway driving
    18.57 MPG 9-4-06
    Freeway only driving
    **On regular un-leaded fuel. I believe the pump says 10% ethanol mix. My bed is empty (99.9% of the time)......I don't drive like, "I stole it." In town.....I drive, "Like an old man." Hardly never, going more than 10 MPH over the posted speed limit on the freeway (or in the city).
    Aloha, Mark
    '95 Silverado ECSB, K1500, Z71, 4x4, 5.7L, TBI, 4l60e 4 spd auto trans, 3.73, G80, LT245/75R16, alum 6 lug wheels, 6 leaf springs on each side, 14 bolt rear, disc/drum (Code JB6-7200 lb rated), 6600 GVWR (Code C5S), HD chassis (Code F44).........basically stock.
    Jan 2007
    McKinney, TX
    Would you say '98 would be the best year for that body style? considering it has the vortec. I'm looking at a few trucks that seem to have 155,000 miles - 105,000 on them. Should I be worried about the 155,000 miles? Was '96 a bad year for the vortec and 4L60E?
    TEE
    TEE is offline
    Sep 2006
    fairborn,ohio
    I would go for one that already has had the intake gaskets replaced...easy to see if you look close enough.
    155 ain't bad as long as it's been takin' care of.
    chevy boy
    Jun 2006
    e-shore maryland
    yea i have a 96 with 100,000 miles on it. i mean yea if you want speed at stock level get a vortec. if your going to really mod the motor id get a tbi. it takes a lot of money but the vortec injection (spider injector poppets) have a limit. if you arent good working on your own stuff and the intake gasket goes...it costs $400 at my dealership to get mine done. the only reason i didnt do it is because i am at school all day and dont have time. so i went ahead and had the dealership do it and they were done the same day i took it there.
    1999 1500 nbs- 4.8, 4x4, performabuilt level 2/3000yank, 3.73s, ls6 cam and valve springs, trick front mount 76 and a fully forged 6.0 waiting in the garage.
    Get in sit down hang on. SolMan98's Avatar
    Jul 2003
    Dallas, GA
    Get the Vortec, better place to start.
    D/D-2006 HHR 1LT 5-Speed.
    1996 Silverado, 5.7, FIPKII, Elect Fans, S/S Headers, Duals, Wait4Me, 4/5 drop on 18" Weld Evo Velosity's. STOLEN ON 9/9/2006
    Jan 2007
    McKinney, TX
    So I guess intake gaskets go like crazy huh?
    chevy boy
    Jun 2006
    e-shore maryland
    haha yea its something about the dexcool anitfreeze that gm used back then. it ate away at the gaskets. mine leaked on the front part of the intake in the corner on the driver side
    Nov 2001
    Newcastle, Texas
    Quote Originally Posted by bowtieb0y
    Wrong...do the research.
    Jul 2003
    Dallas, GA
    Quote Originally Posted by LittleBlueGuy
    One set after 10 years. Not so bad.
    The Warden cedjunior's Avatar
    Jul 2003
    Irving/Valley Ranch, Texas
    Just the original. I can't remember if it had something to do with being over torqued or something like that, but the gasket was just defective.
    1995 K1500, 350, NV4500, 9.5" rear axle
    2009 Pontiac G8 GT 6.0 - 361/385 Stock Cortex Tuned
  17. #17
    chevy boy
    Jun 2006
    e-shore maryland
    well i think the new replacemtn ones they changes the design or something. some people on here can just look at them and tell if they are original or the new updated one
  18. #18
    ASE/GM Cert. Technician
    Aug 2006
    Pembroke, NH
    Dex-Cool does eat away at the intake gaskets. Dex-Cool is an acid base anti-freeze, not an alkali base like the "green" stuff. Alkali attacks corrosion only, acid attacks everything. Read up on Coolants and you'd know this stuff, or just work at a GM dealer for 5 years.
    Follow my ruts if you dare, as crazy as I am, I don't recomend it! 1981 Chevy K30 20" suspension lift, 62" tractor tires, spooled F/R 5 ton Rockwell axles, 630cid blown V-8
  19. #19
    chevy boy
    Jun 2006
    e-shore maryland
    so i was right?
  20. #20
    Nov 2001
    Newcastle, Texas
    Quote Originally Posted by CustoMizedChevy
    Misinformation at its best.....
