Results 1 to 4 of 4
350+ 30 over and stroked =?
This is a discussion on 350+ 30 over and stroked =? within the Technical / Maintenance forums, part of the General Discussion category; What would be the displacement of a small block that started at 350, got a stroke crank, and was bored ...
    Mar 2006
    Austin, Tx
    Exclamation 350+ 30 over and stroked =?
    What would be the displacement of a small block that started at 350, got a stroke crank, and was bored 30 over? Or if it was 40 over? Yes, a 350 with a stroker is a 383, how about the 30 or 40 over?Thanks.
    s10er8
    Guest
    Re: 350+ 30 over and stroked =?
    actually a 383 is a 350 with a .030 overbore and 400 crank
    The Warden cedjunior's Avatar
    Jul 2003
    Irving/Valley Ranch, Texas
    Quote Originally Posted by Bigeats420
    A 350 motor with only a 3.75 crank would be a 377. A 350 with a 3.48 inch crank (stock) and .030 over is a 355. A 350 with a 3.75 inch crank and .060 over would be a 388.
    1995 K1500, 350, NV4500, 9.5" rear axle
    2009 Pontiac G8 GT 6.0 - 361/385 Stock Cortex Tuned
    Mar 2006
    Austin, Tx
    Hey, thanks.
