Results 1 to 16 of 16
1995 Chevy TBI running rich....Please Help
This is a discussion on 1995 Chevy TBI running rich....Please Help within the Technical / Maintenance forums, part of the General Discussion category; I have 1995 Chevy Truck with a TBI 305. It has the following: 1. TBI Spacer with a notch between ...
    May 2004
    Spring TX
    1. TBI Spacer with a notch between the bores
    2. Injector Pod Spacer
    3. Adjustable FPR (set at 13 PSI)
    4. Power Charger Bowl
    5. Shorty Headers
    6. 3" Exhast w/ a D-max Bullet
    7. 160 Degree Thermostat
    Right now I have a Code 45 (Rich Exhaust), and Code 33 (error in the MAP sensor signal). The engine is running rich.
    I plan to the following:
    1. Replace MAP Sensor
    2. Inspect ALL Hoses on top of the engine for cracks
    3. Replace O2 sensor of necessary.
    Anything else I should try?
    The truck has 317,000 on the original motor. All of the hoses on top of the motor replaced roughly a year ago. For the passed year, the truck has had regular Seafoam Treatments as well.
    Thanks.
    1995 Chevy Extended Cab 2wd: 14 FF, HSR 406, NV4500, Solid Front Axle
    GMC RULZZ NEUMANNZZ's Avatar
    Mar 2005
    San Diego
    Re: 1995 Chevy TBI running rich....Please Help
    I would make sure your wires and connector going to the map sensor are okay. let us know what happens.
    Matching Ninja 500r
    05 GTO upgrade.
    Apr 2004
    Texas
    160 thermostat will make it run rich because the ECM never sees the engine as being warmed up or closed loop as the tuners call it.. Go back to the 180 thermostat and I bet it will go away.
    1991 C1500 Ext. Scrapped. I still have the engine, tranny and Detroit tru-trac.
    2005 GTO LS2 with full Pedders track II suspension. StreetsweeperHT cam with Kooks exhaust. Tuned.
    Registered User Alexander's Avatar
    Aug 2005
    Edmonton, AB
    Fix the problem with the MAP first, everything else is secondary. The map sensor is like the crystal ball for the PCM, and lots of weird things can happen if it's not working right. Also, no need to change the O2 sensors, they appear to be working (they told you you were running rich, right?)
    4th year GM Apprentice - on active Army service.
    1990 GMC Sierra C1500.
    350 w/comp cam, superchips computer, K&N air filter, dual Magnaflow exhaust, 3.73rear end, brown and bronze paint (with stylish orange pin-stripe), and rust.
    May 2004
    Spring TX
    Quote Originally Posted by TITANIUM
    I was afraid it may have been the T-stat. I figured 160 Degrees would be warm enough for the ECM to go to closed loop. What is the ideal closed loop temp?
    May 2004
    Spring TX
    Quote Originally Posted by Alexander
    I am going to replace the MAP first since the one on there is as old as the truck. Hopefully that will change something.
    05 GTO upgrade.
    Apr 2004
    Texas
    Quote Originally Posted by axisT6
    It depends on what ECM you are running.
    May 2004
    Spring TX
    Alright, the MAP sensor has been replaced, and the stock 195* T-stat has been installed. Still Rich.
    I am going to replace the Plugs, Wires, Cap, Rotor, and O2 sensor since they are about due. Hopefully this will result in a much better spark and AFR reading for the ECM.
    Based on the info in Post #1, can anyone else see any reason why I would be running rich? By the way, I have no vacuum leaks, and the only code I am throwing is CODE 45 (rich exhaust).
    May 2004
    Spring TX
    I also discovered that the media inside the catalytic converter is loose and rattling. I am guessing that this is a result of the rich condition.
    Registered User young blood's Avatar
    Oct 2007
    burleson
    turn your fuel pressure down a little see what happens
    May 2004
    Spring TX
    I tried that, but it wont adjust below 13 PSI.
    Jul 2006
    Colorado
    computer will hit closed loop at around 100 deg F.
    can't turn it down below 13? huh.
    it might be the CTS in the manifold. those are pretty cheap, so I would throw a new one on. plus they're easy to change
    91 K1500 ECSB
    LQ4/80E/241/60/14SF/4.88/38s
    EFILive
    98 2Dr Tahoe
    L31/0411/60E/241/4.10/285s
    EFILive, NBS 10b w/discs
    May 2004
    Spring TX
    Quote Originally Posted by 91chevZ71
    The adjuster screw on my AFPR hits my fuel line right at the 13 PSI setting, thus, 13 PSI is as low as I can go.
    I am guessing CTS = Coolant Temperature Switch??
    Thanks.
    05 GTO upgrade.
    Apr 2004
    Texas
    Anything that will cause your engine to flow less air in or out such as a clogged up air filter will cause a rich condition. A sticky injector will also do it.
    May 2004
    Spring TX
    I normally seafoam the truck both through the gas tank, and through the PCV hose. I would like to think that I don't have a sticky injector. The air filter does not need replacing yet.
    May 2004
    Spring TX
    By tomorrow, I will have replaced the following:
    Stock plugs with Delco Rapid Fires with .054" gap
    Stock coil with MSD Blaster Coil
    Plug wires
    Cap
    Rotor
    Manifold Temp Sensor
    O2 sensor
    This better work!
