Results 1 to 10 of 10
4.3 to 5.0 swap
This is a discussion on 4.3 to 5.0 swap within the Technical / Maintenance forums, part of the General Discussion category; I was wondering what would be involved in swapping out a 4.3 v6 for a 5.0 v8. I have found ...
    Registered User ABK1500's Avatar
    Oct 2007
    Minnesota
    Talking 4.3 to 5.0 swap
    I have found many posts for the 4.3 to 5.7 swap. Is it because it is an easier swap? Or is it a easier engine to find? It is for a 98 k1500 with 5 speed,and I would look for a 5.0 vortec also, mixing tbi and vortec adds so much to the swap. I understand that the mounts would have to be changed, but will the engine bolt up to the transmission (and will the transmission will be able to handle it?)I also understand that you would need a new computer? Thank you for all help.
    Homesick NBer
    Jul 2005
    Edmonton, AB (but still an easterner at heart)
    Re: 4.3 to 5.0 swap
    Quote Originally Posted by ABK1500
    the trans will bolt right up, if the engine is from a 93to 95, then its no problem cause it would have the 4l60e trans behind it, which is what the 96up engines run, but if the engine is from an 88-92 then the trans will still bolt up but the pre 93 trans was the 700r4, same case, but not elctrontic, so yes it would handle it just fine.
    and yes 350s are easier to find than the 305, and most people would prefer to have the 350 anyway.
    2003 Chev Silverado 4x4 4.10 gears and it has a 4.8L
    1997 GMC Sierra 4x4 4.3L 4L60E KOSS CD player,16mpg,3.73 gears z71 skid plates <<<sold
    4th year apprentice at Chev Dealer
    Diesel Nut justy's Avatar
    Dec 2006
    Minnesota
    Re: 4.3 to 5.0 swap
    People pick the 350 because they have a little more horsepower. About same fuel mileage as the 305. And also if a person wanted too they can get performance parts easier for the 350, then a 305. Although I see alot more performance parts for the 305 that camaro used alot.
    Transmission will work fine.
    2007 3500HD NBS Duramax
    Oct 2007
    Minnesota
    Re: 4.3 to 5.0 swap
    so the 305/350 will bolt up to the 5 speed just fine. I believe you need to get a new computer from the new motor, but where is the stock computer located? Also, all of the a/c, etc.. bolt up to the v8?
    Oct 2007
    Minnesota
    Re: 4.3 to 5.0 swap
    Will the brackets and accessories bolt up? Where is the computer located?
    6 cylinders of fury... 91 V6 4x4's Avatar
    Sep 2007
    White Suburbia or Amish Country
    Re: 4.3 to 5.0 swap
    Another reason people go for the 350 swap. The 4.3 is the same engine with two cylinder chopped off, so most if not all the accessories will bolt right up. I want to swap my 4.3 out for a TPI350 within the next year.
    ~ Derek
    1991 Chevy K1500 - 4.3 liters of slow.
    R.I.P. Matt 3/21/85-1/23/04
    R.I.P. Ben 12/16/86-9/5/07
    claviz13
    Guest
    Re: 4.3 to 5.0 swap
    Skip the 5.0 and get a 5.7. You'll thank me later.
    Oct 2007
    Minnesota
    Re: 4.3 to 5.0 swap
    does anybody have any good sources for engines?
    Homesick NBer
    Jul 2005
    Re: 4.3 to 5.0 swap
    the computers on 96 up trucks, are under the hood on the drivers side, in front of the fuse box. 88-95 the computer is behind the glove box, on top of the blower motor.
    Dec 2006
    Minnesota
    Re: 4.3 to 5.0 swap
    I would get a hold of a vortec 350 (96-99), Go to a junkyard 1996-99 (c/k 1500) and grab a computer from a truck with a manual 5 speed. The computer is on driver's side under the hood. Then you can drop in your new engine and switch the computer.
