Results 1 to 7 of 7
97 Tahoe, Shift Lever Won't Move When Engine Cold
This is a discussion on 97 Tahoe, Shift Lever Won't Move When Engine Cold within the Technical / Maintenance forums, part of the General Discussion category; my friend has a 97 tahoe and just got a tranny rebuild, now he cant shift into gear unless he ...
    Registered User Grif's Puma's Avatar
    Dec 2007
    Blood Gulch
    my friend has a 97 tahoe and just got a tranny rebuild, now he cant shift into gear unless he lets is run for a few minutes. he says the lever will not move, even when stepping on the brake. my guess is the brake lockout switch is bad, how does it work and what needs to be done to replace it?
    165K , 3.73 , 15 MPG, 32 Gal, TBI Spacer, airbox!, Flowmaster. http://www.cardomain.com/id/94scrmnchkn
    USMC
    Oct 2007
    TN
    Re: 97 Tahoe, Shift Lever Won't Move When Engine Cold
    What kind of fluid did was put in the tranny?
    My guess would be the lockout, but it runs off press or something. (guess)
    Maybe wrong fluid, bad pump.
    Haven't heard of this yet.
    05 Cavalier
    74 Corvette Stingray, 350, 4 speed
    Dec 2007
    Blood Gulch
    his rebuild was done by AAMCO... i know, i tried to get him to take it somewhere else, where i had mine done, but it was warranty work so his options were limited.
    are you saying the brake pedal lockout switch that releases the shift lever is activated by trans fluid pressure? i'm not sure im understanding you correctly
    USMC
    Oct 2007
    TN
    That is a thought. I have no idea, though.
    Just kinda thinking out loud.
    05 Cavalier
    Dec 2007
    Blood Gulch
    he hasnt told me if it did it before the rebuild or not. but AAMCO wanted an outrageous price to fix it, so he told them where they could stick it. i plan on asking the guys at NAPA next time im there how much that switch is and what the deal is with it.
    USMC
    Registered User TurboJugend's Avatar
    Dec 2006
    Canada
    i doubt this is related.
    but i had a quad that wouldnt shift into gear when it was in the -'s
    i think there was water in the t-case and you couldnt shift that thing for ****. but ofcourse when she warmed up it was fine
    Dec 2007
    Blood Gulch
    i agree it's weird, but he says that it just won't let him actually move the lever with his hand into gear unless he waits a few minutes with the engine running. Nothing to do with the actual transmission under the truck. just that the lever refuses to move if the truck is cold. i was like Whiskey Tango Foxtrot when he told me over the phone, so i figured i'd bring it to the forum.
    USMC
