Results 1 to 18 of 18
Gas gauge reads full all the time?????
This is a discussion on Gas gauge reads full all the time????? within the Technical / Maintenance forums, part of the General Discussion category; How would I fix this problem....
    Registered User 90Z71Stepside's Avatar
    Mar 2008
    Montana
    Oct 2007
    TN
    Re: Gas gauge reads full all the time?????
    Sounds like you have the guage grounded.
    You need to check your wires.
    I think you can pull the plug on the tank/sending unit, and see what the resistance is. You will need a book to tell you what it should be between full and empty.
    If that reads good, start checking your wires.
    05 Cavalier
    74 Corvette Stingray, 350, 4 speed
    Isn't so crazy afterall? crazyboy's Avatar
    Mar 2008
    NJ
    wish mine was full all the time!
    Jun 2006
    TN
    Quote Originally Posted by crazyboy
    no doubt!
    2006 GMC Sierra SLT Crew Cab Z71
    Oct 2007
    TN
    That's a nice thought.
    I wish my Ford was full all the time. 10 miles a gallon sucks!
    Bad thing is I bought it cause I wanted a 3/4 ton to pull my trailer, but my 1/2 Chevy pulls better, and gets better mileage.
    05 Cavalier
    Jan 2007
    philly
    Lucky you, mine seems to be stuck on empty
    1998 Chevy K1500- Used, Abused, and Sold 1989 Camaro Iroc-Z 5.0, auto....- Sold
    1987 Dodge Dakota 2bbl, 5 spd, v6, 4x4, -scrap
    1993 Honda CBR600 F2- DD when nice out 1987 k5 blazer- bad ass
    Oct 2007
    TN
    My chevy is stuck about 1/4, my Ford is stuck past empty on both tanks.
    05 Cavalier
    Registered User half ton z's Avatar
    Jun 2004
    central ohio
    I think you might have a broken wire. Most likely a rusted through wire terminal connection at the top of the sendind unit (on top of the tank).
    There will never be enough time untill there is no time.
    Registered User dave89iroc's Avatar
    Sep 2007
    SE Michigan
    unplug the plug to the sending unit and ground the purple wire, if it drops to E, you need a new sending unit
    2000 Silverado 6.0 4L80E 2wd
    Oct 2007
    TN
    If he has a broken wire it should drop to E.
    Like dave98iroc said, if you ground the guage it should peg F, if it goes to E the guage is bad. Unless you don't have power to the guage. I am still going to go with the guage being grounded.
    If you take the ground off and the guage drops, it should be a bad wire.
    05 Cavalier
    Habitual Troublemaker cancritter's Avatar
    May 2006
    Alberta Canada
    gadge grounded or sending unit stuck in position
    [Stole/FOUND 13/03/08 :O)
    91GM 4x4 excb 5.7 @ 40 over, Westers,Eld 3704.Lunati Trickflow 195 @1.6 RR,Walpro 190/overbuilt 700r4 /TCS TC,4.10/tru trac,14 blt,Hooker LT,areofilter,Extreme TBI.MSD.AGR still adding
    70 fury 3
    71 sport fury GT
    "the kid"
    Nov 2007
    Melbourne, FL
    mine reads 1/4 of a tank over and im out of gas before i get to the 1/4 tank mark . . . most people told me it was either a grounded guage, sending unit, the stance of my truck, or the floater was messed up . . . if i were you i would get a new guage
    1993 Silverado rcsb, hho injected, cold air, ceramic coated shorty headers, true duals into dynomax ultra-flow x, 2200 stall, shift kit, etc.
    1990 geo el cametro
    Sep 2007
    SE Michigan
    Quote Originally Posted by kcb37
    on a pre vortec, open wire goes to F, shorted goes to E
    the newer ones go to E when open, because the BCM treats E as the default for any problem with the circuit
    May 2009
    Kaneohe, Hawaii
    Reviving this thread.
    I recently picked up an 89 Scottsdale w/the same problem. I tried unplugging the harness and grounded the purple wire and guage still read full so I'm thinking the sending unit is good. My odometer and trip meter is out so I'll check the ground on the gauge and see what happens. Any other input will be greatly apreciated!
    May 2009
    Kaneohe, Hawaii
    Quote Originally Posted by dave89iroc View Post
    I have a pre vortec so I have an open wire? When you say open wire do you mean cut/broken but NOT grounded? I checked the purple wire at the connector before the fuel sending unit and had no power. I haven't checked it coming out of the gauge cluster yet though. I SHOULD have power coming from the gauge cluster right?
    Also, not sure if this is related as well but I think the oil pressure gauge is pegged as too.
    1989 C1500, SCSB, 5.0, TH400
    Sep 2007
    SE Michigan
    Quote Originally Posted by DOLO View Post
    yes, not much though, use a volt meter to check
    and yes, open is NOT grounded
  17. #17
    May 2009
    Kaneohe, Hawaii
    thanks for chiming in and clarifying that for me. Hopefully, I'll get some time this weekend to work this out.
  18. #18
    Badass Bowtie djumpr1's Avatar
    Dec 2005
    VA
    i have the smae problem and oil pressure is maxed also where are the grounds located do i have to take the dash all apart
    88 Chevy 2500 6" lift, 35's, 4.56 gears, disc brakes, headers, flowmaster 40, never ending project....
