Results 1 to 3 of 3
99 silverado quad high beam and fog wiring
This is a discussion on 99 silverado quad high beam and fog wiring within the Technical / Maintenance forums, part of the General Discussion category; Got done setting up quad high beams on my 99 silverado and thought I would save a few others the ...
    Jul 2008
    South Dakota
    Got done setting up quad high beams on my 99 silverado and thought I would save a few others the head scratching of how to do it without a kit. I believe this should work for 99-02.
    Use standard 30A relays for this
    For quad high beams
    30- LH low beam yellow wire (-)
    85- LH high beam purple (-)
    86- LH high beam orange (+)
    87- Ground
    To turn on fog light with high beam (second relay required)
    (wont shut off w/ fog light switch on high beam)
    30-(Under fuse block) white connector, row 4, 2nd pin (purple)(+)
    87- 12V (+)
    Have installed and working.
    Hope this helps someone. It took me a little bit to figure it out.
    Hired Goon Aloicious's Avatar
    Mar 2007
    UT
    Re: 99 silverado quad high beam and fog wiring
    Quote Originally Posted by bondoman
    For quad high beams
    87- Ground
    87- 12V (+)
    Nice write up. welcome to the forums BTW.
    1996 C1500 ECSB 5.7L AKA the "LS31", distributorless w/LS2 coils, RHS Heads, ZZ4 Cam, T56 6 speed, 12200411 PCM, 4.88s...Coming soon: forged twin turbo 383..
    May 2013
    NC
    Quote Originally Posted by bondoman View Post
    For quad high beams
    87- Ground
    87- 12V (+)
    Can you add more details to this? I know what the relays are and how to determine the numbers for the pins, but which relay did you use and what do the colors correspond to? thanks in advance... I've searched the internet for this answer and for the 99, there isnt an easy answer out there.
